Results 1 to 10 of 10
03-06-2012, 11:56 AM #1
Toyota Nut
- Join Date
- Dec 2011
- Location
- Tulsa County, OK
- Posts
- 702
Crank Bolt Came Off! Liquid Wrench Is My Hero
I have been fighting for a month to remove the crank-shaft bolt on my 5MGE. The engine is out of the car and I tried all the tricks including WD-40, locking the crank with a wedge, locking the flywheel, heat (in moderation), hammering on it for minutes at a time with a 1/2" impact, breakover bar, etc. Last friday I soaked it with Liquid Wrench and let it sit all night, still no luck. I finally gave up and decided I was going to take it somewhere with a 3/4" impact and large compressor and take my chances on breaking the bolt. I even called the machine shop and asked them if they would deal with it if the bolt was broken off in the crank. Of course, I would have to remove the crank from a low mileage engine (not cool). Yesterday after work I went out to the shop and was prepared to load the engine on my trailer and take it somewhere. I thought one more try, I put the impact to it and the bolt immediately came out.
My lesson in this is that the Liquid Wrench may take time to work and to give it several days if needed. I have removed a lot of crank-shaft bolts in my 35 years of working on cars and I have never seen anything like it. Toyota sure knows how to put them together. :-)
BTW, I already got a new bolt from Mark.
03-06-2012, 05:09 PM #2
Nice. Pain in the butt to work on I guess but good quality... that's Toyota. haha
1982 Terra Cotta P-Type
Need boost...
03-26-2012, 01:22 AM #3
CelicaSupra.com Member
- Join Date
- Nov 2011
- Location
- wisconsin
- Posts
- 162
couldn't you just spray it with liquid wrench, brace a breaker bar against something, and use the starter?
03-26-2012, 11:05 PM #4
- Join Date
- Apr 2008
- Location
- nashville tennessee
- Posts
- 448
no because he said it was out of the car. ive never actually had luck with the starter bump. ive always used the rope method. i have done it a number of times. i am just finishing my rebuild and all the valves checked out within spec.
pb blaster works well. im out right now, maybe this time ill try your liquid wrench!www.sparrowmotive.net
Demoted to rank of Driveway Grass Killer First Class:
1985 Toyota Celica/Supra 5M-GE 5spd 270,000 miles and ticking( no really the engine is ticking)
03-27-2012, 10:35 AM #5
Toyota Nut
- Join Date
- Dec 2011
- Location
- Tulsa County, OK
- Posts
- 702
05-25-2012, 04:29 AM #6
- Join Date
- Jul 2008
- Location
- Hawaii
- Posts
- 260
Instead of wasting a month it would have been much easier doing it the right way, using the Toyota Special Service Tools (that OTC handle that holds the OTC dampener holder, and that OTC Dampener holder that bolts into the treaded holes in the Dampener). Once you remove the radiator and all the belts it only takes like half an hour or less to remove the dampener the right way (right tools for the job), same thing with installation (it is not very easy to torque to the required specifications without the right tools).
There is also a tool that is not OTC, to actually pull the dampener off without damage, that screws into the internal threads of the dampener.
Removing the Main Crankshaft DAMPER many of the other ways you can permanently damage the Rubber part of the DAMPER (take a guess how I found out) as well a crack the actual Pulley part (were the belts ride in). Not to admit anything, it took almost forever to find another dampener.
05-25-2012, 09:16 AM #785' P-Type 6m/ 5-speed/ White/ maroon leather
05-25-2012, 10:10 AM #8
- Join Date
- Apr 2008
- Location
- Posts
- 448
they do have the Toyota sst super center on every island in Hawaii. so I've been told. us main land folk have to pay hundreds at the stealership or make one at home like i did. is easy is you have access to a machine shop. a machine shop could do it pretty cheaply as all you need is to drill a few slotted holes. i can get pics of needed
05-25-2012, 10:25 PM #9
You can get the pulley holder 2 piece set-Actual holder, and special bracing wrench, for between $100-$200 from internet tool sellers. They fit multiple applications. Google the SST#s. The different brands- like Kent-Moore, OTC, SPX, Toyota-are all made by the same company.
05-26-2012, 07:36 PM #10
Toyota Nut
- Join Date
- Dec 2011
- Location
- Tulsa County, OK
- Posts
- 702
Engine was out of the car, I was putting all of my weight on a 4 foot breakover bar with another bar holding the flywheel.. If the bar had broken it would have really jacked me up. I got to the point I was worried about me, I have another dampener.
1985 Supra Mk2 P Type, 2JZ transplant patient.
