Results 1 to 10 of 17
Thread: LED lights??
06-14-2012, 12:50 AM #1
LED lights??
Has anyone done LED taillights and marker light set up?? Could this be done???
06-14-2012, 01:12 AM #2
you can replace the regular bulbs with led bulbs and it looks way different. depends what style of led bulbs u buy. i converted all my interior lights to led. and i love it!!
06-14-2012, 08:25 AM #3
CelicaSupra.com Member
- Join Date
- Nov 2011
- Location
- wisconsin
- Posts
- 162
my tails are SMD LED. Really crisp light outta those. and super bright too!
06-14-2012, 09:17 AM #4
I believe Tanya did LEDs in a thread some where.
Matt K.
06-14-2012, 12:35 PM #5
I have seen the one for LED cluster but have not seen one for taillights and such. Mainly curious how hard it is to do.
06-14-2012, 02:52 PM #6
- Join Date
- Nov 2011
- Location
- wisconsin
- Posts
- 162
here is a link to the ebay page where I got mine. Super cheap too.
http://www.ebay.com/itm/T25-BAY15D-1...#ht_1859wt_952
06-14-2012, 02:55 PM #7
- Join Date
- Nov 2011
- Location
- wisconsin
- Posts
- 162
Here is for the turn signals in the back...
http://www.ebay.com/itm/1156-BA15S-6...item337775e22d
06-14-2012, 04:20 PM #8-Chris
1983 Celipra GTS:
06-14-2012, 04:25 PM #9
06-14-2012, 08:13 PM #10
Yep, pretty much any bulb in the car has a direct bulb replacement.
-Chris
1983 Celipra GTS:
