Results 1 to 3 of 3
    Nov 2011
    South Dakota
    3
    extra wiring plugs?
    Hi there my name is Robert and I recently bought an 82 Celica Supra that had a blown headgasket and was already torn apart. I put it back together doing the best that i could to find where everything goes. almost everything seem to fit up except for three wires.
    The red clip to the very right i'm pretty sure doesn't go to anything cause it was all bundled up and taped originally.
    The brown wire in the middle I just remembered goes to the water temp sensor underneath the distributor.
    so the plug in question is the green plug on the very left. I know it doesn't go to the water temps on the water outlet housing because they have little key slots so it doesn't fit. Is this important and where does it go? I wondered if it was just extra cause in the TSRM it says this harness works for both the 5mge and 7mge. Am I correct in thinking that?
    Also I wanted to make sure that I have the two single wire white plugs in the right spot, since for some reason i'm not getting spark or a CEL when i turn on the car it turns over just fine so I just want to make sure I have everything on right before I get to far into tracing back wires and fuses and stuff like that. I know that it's not the coil cause i put one on from my 22re truck that I know worked and that didn't solve the problem.
    this is the white wire that comes from underneath the coil that i have pluged in to the wire that goes somewhere down by the crank I believe.
    this is the plug that comes from the wiring harness by the injectors and I have it connected to the wire that comes up with ground wire IIRC. I don't think i can have them mixed up cause they really don't fit when i tried swapping them but i just want to make sure that i've got everything in the right place.
    Thank you for your time and help in advanced.
  2. #2
    Make sure the ecu fuse is good (driver kick panel), sometimes simple things need check first, also if you find the fuse good, with key on ignition, brush your fingers across the fuses while watching cel and if it lights you need to bends the fuse tabs slightly for able better connection. Good luck.
    '84 6mge R154
  3. #3
    Aug 2009
    Nova Scotia
    2,292
    Your pics aren't working, for me at least - are they posted on another site and pointed to?
    Double check that all your grounds are good. '82 doesn't have CEL.
    '82L - Terracotta Warrior
id=a6141150">
