Results 1 to 5 of 5
Thread: Fog light wiring
07-04-2012, 07:44 PM #1
Fog light wiring
The 194 bulb on my fog light that's on the right hand side doesn't plug into anything, it a t shaped plug and i cant find where it connects to, I have looked all over. would it be possible to "rig it" onto the left hand side bulb wires to make it work? its an 84 supra
-For honda fans
07-04-2012, 10:38 PM #2
I am not really grasping what you are saying but the foglights are H3 which has wires coming off of them and not 194's. When you pull your fog you almost have to flip the rubber boot inside out to see where those wires detach allowing you to remove and replace the bulb. Hope that helps
This message will self destruct
07-04-2012, 11:28 PM #3
yeah there is just one power wire going into the housing and the ground is just through the casing. so if you have one wire you're golden!
82' fresh paint 7mgte -___- 11k+ deep
What am I doing currently?
What kind of oil should you run?
Lexus afm and 550cc injectors?
Exhaust & Intake cam timing?
07-05-2012, 01:21 AM #4
The 194 light is the "parking light" next to the fog light bulb in the housing assembly. Both light bulbs share the same wire harness on the fog light housing and plug into the main body harness (white connector) that runs across the whole front of the car. Are you saying that one of the wires from the 194 parking light bulb is cut and not connected to anything? Here is a picture of a factory fog light housing setup if that would help you at all?
Dave K.
'92T - 346 rwhp / 441 rwtq
'86 P-type - 6M-GE, BPU, JDK V2 short-throw shifter, '88T 3rd brake light
'86 P-type - Dark Blue Metallic - bone stock
07-05-2012, 12:10 PM #5
Yeah it helped, the ground wasn't connected it was spliced but it came undone. i still don't know what the other T shaped plug connects to, its the same 2 wires from the small 194 bulb of the fog light, my guess is that the previous owner tried to mod the lights.
-For honda fans
