Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jun 2012
    Spingfield mass, I live in place were we in total have 6 or7 Toyota s it's verry cool
    15
    The 5 mge won't start a need help bro
    can some one help my supra ! Something shut out the fuel and spark , I know a lot of cars but this one has been around for like a year and a half sometimes it asks like its going to fire .but only backfires ,I did the time ing about 100 times ,need help I'm going thru the wires now
  2. #2
    Aug 2010
    Colorado
    843
    if its backfiring them you probably have some sort of spark going on...
    82 L Type
  3. #3
    Jun 2012
    15
    So I called the guy who sold it to me and he sead that ther was a at trans and thay placed a 4 speed and I seen it on and even whipped 2 donuts at about 2300 rpm and it had a bad head gasket on number 4 to5 space between piston area was missing ,so I put a new thermogasket and cleaned it .put it all back and nothing .
  4. #4
    Jun 2012
    15
    Trust me something turns off the distributor and the fuel pump cuz I left the filter lose just a bit so that I know when that starts leaking, the spark comes on ,and I con try to start it ,but it backfires .
  5. #5
    Aug 2009
    Media pa
    1,250
    Ok I don't know where to start here. You need to proof read your post. Its hard to understand what you are saying. I am not perfect either but it goes a long way.
    First pull the coil wire from the dizzy end. And test it with the screw driver put a screw driver to the tip of it Crank the car if you see a spark the coil is working. Then pull a plug wire out of the dizzy and test it the same.
    Listen for the fuel pump to turn when you turn the key to the on position.
    But as said before if you are getting a backfire. You have to be Getting some spark and fuel.
    Do your cams line up ? Is your crank lined up? Connector pumped?
    Matt K.
  6. #6
    Auburn, WA.
    5,757
    Great Video!
  7. #7
    Jan 2006
    Back Home
    1,098
    That ther wuz a hard reedin
    Bob.Big Boosted Six.Makes more torque than the front line at a Honda dealership!
  8. #8
    Nov 2006
    Sherbrooke Quebec Canada
    84
    Sounds like bad timing from the Dizzy
  9. #9
    Nov 2011
    Manchaca
    114
    Click on the link in my sig and start reading :-D
    Best of luck.
  10. #10
    Jun 2012
    15
    Ok I did the loser thing ,but im more shore about it . I gave a semi whatever paintgun to this dude he was about 50 , and he sticks his finger in spark plug hole has me crank it and found a point and compression stroke ,he moves the distributor about 2teeth ,oh and sead this car will shut of the fuel pump if pressure is not met .so he took one look at the wires and knew instantly thay were from the automatic transmittion ,and placed a wire b+ to a black w red line wire, boom the fuckin thing comes on oh and stuck a crescent wrench in the amf , from allthat he found out the( damper assy )is broken or sticking , I mean, am I right ? What did miss , ?
id=a6141150">
