Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Apr 2008
    missoula montana
    1,164
    mr2 agx vs supra gr2
    So my kyb agx's I bought from george at raptor racing are completely blown but what I was thinking is they blew cause mr2's are alot lighter so they dont have the right valving for our cars. Not positive thats why they blew but just a thought. My ultimate question is what do you think would be better for track/auto-x/drifting kyb agx's for the mr2 or kyb gr2's for the supra's. The reason I bought the agx's in the first place is because my car is lowered and the mr2 struts are shorter so I thought that would help with that issue. Or I might have received a bad set which happens and I really dont care, but just looking for opions on this. Kyb gr2 for supras or agx's for mr2's? Just hate buying and regreting ya know but thanks in advance guys!
    82' fresh paint 7mgte -___- 11k+ deep
    What am I doing currently?
    What kind of oil should you run?
    Lexus afm and 550cc injectors?
    Exhaust & Intake cam timing?
  2. #2
    Nov 2004
    Graham, WA
    5,080
    Talk to kyb, they usually rebuild their products for the cost of shipping.
    -Chris
    1983 Celipra GTS:
  3. #3
    Jul 2009
    Brooklyn, NYC
    1,218
    Ill buy those AGX if you dont want them. Mine are warrantied and I can get them replaced. Please let me know.
    1984 Supra P-type: 5MGE/W58 Swap/4.10 LSD. Cressida BBK. Under the knife for the winter.
    1985 Celica GTS 'Vert: 22RE/Auto Undergoing resto and Engine/Trans/LSD swap
    1986 Cressida: 5MGE/W58/LSD. Supermonitor. AGX Rear. Daily Driven.
    1987 4Runner Turbo: 22RTE/Auto. Digital Dash. Inclinometer. BHG. To be running someday.
  4. #4
    Auburn, WA.
    5,757
    Not enough info-Coilovers, or stock setup? Spring rates? Driving style/frequency? Example-I got about a year out of a set of AGXs with a 550# coilover aggressively driven/multiple track day daily driven setup-I ve been getting 2 years from a 400# aggressively driven daily driven setup-Most folks report you get LESS mileage from GR-2s, my experience says the same. There is a tradeoff for more aggressive dampning, you know..Most of us running Agxs just turn up the dampening as the strut insert ages..
  5. #5
    Jan 2009
    oxfordshire, united kingdom
    104
    Or do what i did and make it shit hot with some 2nd hand branded coilovers from a Nissan 240sx hatchback and Make/ buy some sleeves to weld on the spindles. I don't know why everyone is so scared to do it really?! Full damper travel at any given ride height is about the best you could ever hope for and it's soo bloody easy to do.
    I used the rears too, but retained the stock rear spring position for various reasons.
    From a recent 1700 miles of thrashing the absolute nuts off my car i can say, a decent set of coilovers and whiteline adj anti rollbars with some sticky tyres produce mind warpingly amazing handling on our old supra's.
    More info below
    http://driftoy.proboards.com/index.c...lay&thread=210
    http://driftoy.proboards.com/index.c...lay&thread=252
  6. #6
    Apr 2008
    missoula montana
    1,164
    Yeah I have the budget coilover kit that im pretty sure came with the 550 lb springs in the front and its pretty low also compared to stock that is. I think what im going to try is buy the cheapest struts i can find just to hold the place of my agx's and send them off to be rebuilt and also buy the strut tube spacers from george at raptor racing and i think it should do quite well I will let ya all know once its all done
  7. #7
    Apr 2008
    missoula montana
    1,164
    Killbill oddy yeah I have seen that thread and read all of it of course and its awesome! thats what I want to do in the future but right now im just going to stick with my setup for this summer. maybe during winter i could do the change over which would be awesome but thanks for bringing this back to my attention!
  8. #8
    Feb 2004
    Calgary, Alberta, Canada
    2,038
    +1 on AGXs and strut tube spacers. This is by far the best solution.
    '84 P-type, 5spd, torrid red, black/grey leather
    Built 7MGTE (JE's, ARP studs, MHG), BOSS STG4 60mm, AEM standalone, R154, 2 1/2" IC and 3" turbo back - the works
    Coilovers, ROH wheels, 4 corner BBK, Konis, ADDCO bars, PST bushings etc. etc.
  9. #9
    Jul 2009
    Brooklyn, NYC
    1,218
    Dont you have to redrill the strut towers to use the S13 camber plates?
  10. #10
    Jan 2009
    104
    Quote Originally Posted by TransAmBandit View Post
    Nah, they bolt straight in on the pcd, but they are about 30 degrees off horizontal if you want camber adjustment only. otherwise castor increases at the same time. so then you would have to redrill your towers. the wheel does respond faster with a bit more castor though, so up to you on how you want the car set up.
id=a6141150">
