Results 1 to 7 of 7
Thread: no crank?????
    Hamilton OH
    790
    no crank?????
    I have had is problem multiple times now. Everytime is seems to be the battery terminals. I have changed them once already but it continues to do the same thing. Power is alright everywhere but there not enough contact to get the starter to budge. Is there a heavy duty racing set or something out there i can get? This is getting annoying to say the least. I can see all the vibration making the terminals loose but there has to be something to stop this.
    Mar 2011
    Nashville, TN
    107
    For me i always cleaned the connection at the starter as well it gets corroded and will not pass enough amperage. It also may be a sign the starter is bad. Clean the starter terminals and it it goes away away for a while and then returns its the starter.
    Hamilton OH
    790
    There not corroded. I took off both positive and negative terminals and bought new ones to replace them with. I took off the cable at the starter and cleaned it up. Still nothin. WTF???
    Nov 2004
    Graham, WA
    5,075
    Contacts in the starter could be going out. Cheap to fix and the hardest part of replacing them is getting the starter out/in the car.
    -Chris
    1983 Celipra GTS:
    6M bored .50 over. 250cc injectors. Delta 272 regrind cams. Carter HF fuel pump.
    Pacesetter header w/2.5" cutsom exhaust. Open air intake filter. 3" piping to TB. 65mm TB & ported AFM.
    4:10 rear from Supra. BillyM shifter kit. Swapped most interior over to black. T3 camber plates.
    935 Budget Coilover kit. KYB AGX struts. T3 Needle bearing upper perch kit. Eibach Sport rear supra springs. SF Ford TFI Performance coil.
    Almost finished with the fiberglass hatch!
    Mar 2005
    Santa Cruz, Ca. 95061
    3,069
    I concur. I would see if the brushes are worn in the starter. At least that's what I think Chris is referring to.
    One trick if the brushes are worn. Turn the key while some friend taps the start fairly hard with a hammer and a long piece of steel to reach it. If it cranks, yes replace the brushes or, ha, ha....buy a used starter from me.
    Quote Originally Posted by 83CelWA View Post
    83-Red P-type , 6M,. LJM strut-bar, RC intake,Thorley header,Tenzo 17" wheels, cross-drilled rotors, Eibach springs, KYB shocks, 85 hatch and int., 82 header panel=Frankenkar
    87 4 Runner, White, 22RE, 302K on original motor, still strong
    "This car is so loud , I heard you before I saw you!" said the nice policeman.
    Hamilton OH
    790
    I searched so different things last night. On thing talked about was the ignition switch. Any thoughs on thats. It sounded like the same symptoms.
    Hamilton OH
    790
    Ok???? I didnt do anything to it and it started. When get time ill have to clean up any ground i can see and see if it happens again
