Results 1 to 2 of 2
    Jan 2011
    CT
    130
    A43DE bolt up to 1UZ or 2JZ?
    I was thinking, why wouldn't an A43DE bolt to a 1UZ? The A340 that comes on a 1UZ or 2JZ bolts to a 5M without adaptors, right? So ghettoness aside, will the 1UZ or 2J physically bolt up to the stock A43DE auto in our cars?
    Make the suspension adjustable and they will adjust it wrong -- look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver.
    - Colin Chapman
  2. #2
    Auburn, WA.
    5,757
    Quote Originally Posted by 1000 Knives View Post
    No. The A340 that comes behind 7ms will bolt right up to a 5m. UZ/JZ block bolt pattern and starter position are different from m series. Bell housing to trans bolt patterns are different between the A4x series trans, and the a3xx trans series. So each engine/trans combo has a unique bellhousing.
id=a6141150">
