Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Dec 2010
    lake stevens wa
    283
    turning problems
    i just installed universal camber plates and gc coilovers and if i turn left my steering will stay left like alignment is off and same for if i turn right.... is it because of the camber plates? or even from the coils?
    i love the feeling of 18psi
  2. #2
    Dec 2010
    Los Angeles
    78
    Check to see if your steering rack bushings are still good, loose or bad steering racking bushings will cause the steering wheel to not center after a turn.
  3. #3
    Dec 2010
    lake stevens wa
    283
    ok thanx i will check can that happen front dropping the strut/spindle?
  4. #4
    Aug 2009
    Media pa
    1,250
    Did you mess with the tie rod ends?
    Matt K.
  5. #5
    Dec 2010
    lake stevens wa
    283
    No but looking at it now it looks like the Driver side is turned left and the passenger is turned right
  6. #6
    Auburn, WA.
    5,757
    Are your brakes now in front of the wheel centerline?
  7. #7
    Aug 2008
    baltimore
    3,095
    install your wheels in the right way and you wont have that problem.
    Edgar M.
  8. #8
    Feb 2007
    Erie Pa
    947
    The top hat of your strut may now be interfering with the inside of the strut tower, along with the many other issues mentioned before me.
  9. #9
    Jul 2011
    everett wa
    235
    Quote Originally Posted by zuprax85 View Post
    how do you put wheels on incorrectly? last time i checked there's only one way
  10. #10
    Dec 2010
    lake stevens wa
    283
    Yeah put them on right???
id=a6141150">
