Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Jul 2012
    Salem, Or
    3
    Rear hatch glass removal, seal replacement - Rust-
    Ive got a 83 Supra - Im looking for some help on how to remove the glass. and is it possible to find the window seals new? ive got some rust ive got to work on.
  2. #2
    Aug 2008
    baltimore
    3,095
    Edgar M.
  3. #3
    Jul 2012
    Salem, Or
    3
    Thanks! much appreciated!
  4. #4
    May 2011
    Owen Sound, Ontario
    2,622
    Hey I need to do the same thing this winter.
    If it helps, Mark at Vancouver Toyota quoted me $73 for a mk3 rear hatch seal (body to hatch). Mk2 is discontinued but mk3 fits like a glove.
    Can you post some pics please of this project? I could use all the help offered, thanks and good luck
    1982 Terra Cotta P-Type
    Need boost...
  5. #5
    Jul 2012
    Salem, Or
    3
    Awesome! what about the glass to hatch seal? ive got some issues with that one, may just replace if available.
  6. #6
    Aug 2009
    Sydney,Australia
    159
    To be honest this diagram is not very good at showing how to remote the hatch glass and seal.
    Here are some pics from my restore which show it much better.
    http://www.celicasupra.com/forums/sh...A60&highlight=
    If you've ever wondered how you remove the seal this pic shows you. You get a paint scraper push the lip over the metal hatch lip and then use another paint scraper and when necessary a flat head screwdriver to do the area around it then repeat moving around the hatch seal till its done.
  7. #7
    May 2011
    Owen Sound, Ontario
    2,622
    ^ Yeah and this may help (I plan on the same rubber window trim replacement)
    http://www.celicasupra.com/forums/sh...ht=#post776942
    Need boost...
  8. #8
    Charlotte, NC
    1,147
    I use a plastic bike tire lever and detergent.
    RIP Les Grover
    * WANTED mint '84 P-type, any color, no mods, manual trans *
  9. #9
    Sep 2011
    New Jersey
    96
    I've done one from the inside and one from the outside (hatch that was removed from the car). Both worked equally well using a one inch paint scraper and a large flat blade screwdriver. Getting the scraper in there the first time can be a bit difficult, but as you go along it gets easier and easier.
  10. #10
    Jun 2007
    San Francisco
    2,238
    I used wooden clothespins to keep the rubber pulled apart until I could work my way around enough to push the glass out.
    Bad decisions make the BEST stories.
    1982 Supra P-type
    1982 Specific TSRM's
    Wiring Diagrams http://www.scribd.com/doc/44033354/1...iring-Diagrams
    Emissions Repair Manual http://www.scribd.com/doc/44033268/1...r-Manual-5M-GE
    Air Intake System http://www.scribd.com/doc/44033286/1...-FI-46-Thru-52
id=a6141150">
