Results 1 to 5 of 5
    Dec 2008
    richmond va
    79
    85 p type runs rough when warmed up
    Been Running into a problem lately since it's been so hot here.The car will start/run fine till the temp gauge gets to about half way then it sputters for a little bit then evens out but has no power and runs really rough. Was just wandering what could cause this.
    justin
    1985 Toyota Supra P-Type
    1986 Toyota Mr2 (parting out)
  2. #2
    Aug 2009
    Nova Scotia
    2,292
    Could be a clogged cat or 02 sensor
    '82L - Terracotta Warrior
  3. #3
    Clifton NJ
    2,520
    retarded timing + plugs
    84 mt 6mge with intake, exhaust, suspension, brake, and wheel mods
    85 mt 6mge stock
  4. #4
    Nov 2011
    Ohio, United States
    110
    Bad o2 more than likely. Before its warmed up its in closed loop which ignores o2 reading and follows a set fuel map. When warm its in open loop which bases fuel trim from o2 readings
    '86 cressida, 5mge, W58 5-speed swap, CAI, cat-back exhaust, ngk plugs and wires, 12" electric fan. mkII supra Eibach lowering springs, kyb struts and shocks. Black 14x7 +8 Celica-Supra P-type wheels, 1 in bolt on spacers. Black / grey '88 300zx Shiro Edition Recaro seats, AW11 MR2 black leather steering wheel, mkIII supra gt shift knob and pioneer headunit.
  5. #5
    Dec 2008
    richmond va
    79
    Tried just about everything on you guys suggested to no avail, but After a lot of research I replaced the ignition coil seemed to have fixed it
    justin
id=a6141150">
