Results 1 to 8 of 8
    Apr 2012
    vancouver Wa.
    4
    Cool Wanted 6M pistons
    I'm looking for a set of 6M pistons good used set -low miles ( of coarse, and the world) or new even better Rings would be great also. Any ideas on where to even order would help
    Thanks
    Brent
  2. #2
    Jul 2008
    Dallas, TX
    514
    I got mine from here. They are the same as 5m pistons so that's what you need to order. I think I paid around $150.
    85' P-Type 6m/ 5-speed/ White/ maroon leather
  3. #3
    Atlanta
    360
    I have a set that im willing to sell
  4. #4
    Nov 2004
    Graham, WA
    5,105
    Would be better off getting high comp 5m pistons instead of the low comp 5m pistons the 6ms got. Well unless if you are build a turbo motor.
    -Chris
    1983 Celipra GTS:
  5. #5
    Washington State
    3,242
    83CelWA is correct. If you want high comp pistons, you'll need to get pistons from a 84 and up 5mge engine.
    -Aaron
    http://www.rabidchimp.com aaron@rabidchimp.com
    http://www.facebook.com/RabidChimpPerformance
    2415 70th Ave West #31
    University Place, WA 98466
    Providing parts and service to Mk2 Supra owners since 1999
    Send me a text message: 253-237-2368
  6. #6
    Mar 2005
    Santa Cruz, Ca. 95061
    3,078
    Word.
    Quote Originally Posted by 83CelWA View Post
    "This car is so loud , I heard you before I saw you!" said the nice policeman.
  7. #7
    Mar 2005
    3,078
    I thought you sold high comp. postons, Aaron
    Quote Originally Posted by rabidchimp.com View Post
    -Aaron
  8. #8
    Jul 2003
    Naples, Fl
    16,234
    Quote Originally Posted by KJK_Texas View Post
    That site seems to be very general, it lists the 5MGE as being 81-85 and having 8.8:1 compression with no option for the 9.2:1, in which there's a big difference obviously. I mean, this works fine if you want the exact duplicates of the 6MGE pistons, but if keeping the motor N/A< I highly suggest getting the 5M 9.2:1 domed versions instead.
    1985 P-type 5 speed
    6MGE
id=a6141150">
