Results 1 to 10 of 13
Thread: Removal of Cat Converter
07-24-2012, 09:41 AM #1
Member
- Join Date
- Jul 2012
- Location
- emmaus pa
- Posts
- 88
I have a newb question.
If I remove my catalytic converter on an '84 mkii and replace it with a straight pipe, will this generate a check engine light or cause any problems for the engine? The car is emissions exempt so I'm not concerned with higher emissions, I just don't want anything lighting up on the dash or to damage the car in any way.
Thanks!
Josh
07-24-2012, 09:59 AM #2
No, there's no sensors in the exhaust after the catalytic converter.
85 Celica Supra P-Type - 160,000km
07-24-2012, 10:47 AM #3
Member
- Join Date
- Jul 2012
- Location
- emmaus pa
- Posts
- 88
Thanks... As a follow-up what's the difference between just welding a piece of pipe in place of the cat vs. getting a test pipe. I see that the test pipes can be bolted up and I guess removed and put back in place with a cat, but I also see some of them have a fitting on there that looks like for a sensor or something. Do I need to buy a test pipe or can I just have a pipe permanently welded in?
07-24-2012, 11:50 AM #4Dave Harrison
'85 Mark2 7mgte 5sp
'85 Mark2 7mgte Auto
'85 Mark2 7mgte 5sp
07-24-2012, 12:54 PM #5
cut that bitch out, go to auto zone, get an adapter, and find some pipe. My buddy once put a fence post on his old truck, still had mud caked inside of it.
82 L Type
07-24-2012, 01:41 PM #6
Member
- Join Date
- Jul 2012
- Location
- emmaus pa
- Posts
- 88
Thanks for the info guys, so there's no reason to buy a $100 test pipe then, there's no sensor fittings or anything that are necessary to have the car run right. I'm off to knock over a fence!
07-24-2012, 03:08 PM #7
You may want to put a resonator in place of the cat instead of just a pipe, it will kill off the angry bumbebee sound at the higher revs. I have been running the tube style glasspack from thrush for some time now with no problems.
-Chris
1983 Celipra GTS:
07-24-2012, 08:25 PM #8
Toyota Nut
- Join Date
- Dec 2011
- Location
- Tulsa County, OK
- Posts
- 695
07-25-2012, 11:22 AM #9
Member
- Join Date
- Jul 2012
- Location
- emmaus pa
- Posts
- 88
Thanks for the advice about the glasspack/resonator vs. straight pipe!
07-27-2012, 07:03 AM #10
Banned
- Join Date
- Jul 2012
- Location
- london
- Posts
- 1
Wouldn't removing your cat mean that you fail your emissions or MOT test (depending where you are from)
