Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jun 2012
    Bayarea Ca
    28
    The hatch needs to be slam shut very hard to close and lock
    Hi all, my 83 supra L-type needs to slam shut very hard in order to close and lock, but open nice and smooth with both keys or hatch release. I also WD40 it but doesn't help. I am not sure if its original lock or original hatch but most likely it is. Any ideas?
    thanks
    joe
  2. #2
    Nov 2004
    Graham, WA
    5,079
    Adjust the lower latch.
    -Chris
    1983 Celipra GTS:
  3. #3
    Oct 2003
    Montréal, QC
    5,677
    Yes, loose the 2 bolts that secure the latch, raise it 1-2 mm, secure the bolts and try again.
    -Jocelyn
    P85-6MGE SDR(HKS kit c/w IC and F-Con in a box ) 225KKm, NAL seats, 2.5 Brullen, ACT clutch, LJM, SS lines, Trip Computer. EuroH4 + PIAAs
    P85-5MGE SDR had 439KKm (for 17 years my daily runner, RIP...)
    2002 E39 ///M5 LMB
  4. #4
    Jun 2012
    Bayarea Ca
    28
    oh, that U shape anchor right? its actually adjustable?! Great, thanks guys
  5. #5
    Dec 2007
    tx
    455
    I had the same problem in my rebuild and the back of the car where the liscense plate goes had been pushed in some from leaning against it when I was working on it. After pushing it back in line the problem went away. To check it I put some bright lights behind the car pointing at the hatch. I went in side the car and if I could see a light gap in the hatch seal I worked on it a little more until it resealed.
  6. #6
    Jun 2012
    Bayarea Ca
    28
    thats interesting, i should also try that too. thanks
  7. #7
    Jan 2011
    Grottoes, Virginia
    332
    Watch slamming the hatch hard as i will bust the trim from around your tail lights. Just like i did
  8. #8
    Jun 2012
    Bayarea Ca
    28
    hmm, too late, either the previous owner or i already broke it along the corner., good thing that i fixed the hatch. Just broke the dome light switch; square plastic screw anchor, tail light trim. these cars are so fragile. Start thinking about getting rid of it already, sigh.
  9. #9
    Oct 2003
    Montréal, QC
    5,677
    or you are too rough with it, considerinf it's age.
    Don't forget, 29 years old plastic gets brittle.
    -Jocelyn
    2002 E39 ///M5 LMB
  10. #10
    Jun 2012
    Bayarea Ca
    28
    i guess, but still, i was just trying to shut off the dome, and that little switch just broke off, probably just reached the end of its life. good thing i found out the ones from corolla fits perfectly, though doesn't look identical but actually more heavy duty
id=a6141150">
