Results 1 to 6 of 6
Thread: w58 out of an 84celica???
08-04-2012, 02:37 AM #1
Junior Member
- Join Date
- Feb 2012
- Location
- Fairfield, CA
- Posts
- 23
Hey there, have a kind of simple question for all who are familiar with the w58 transmission, I was just wondering if they all have the exact same clips/wires,
I'm running a 92 7MGE out of a cressida in my 82 L-type and swapping its automatic for a 5 speed that I found in the area thats from an 84 Celica, I have the bellhousing for the 7m but just need to know if the wires will hook up the the 7m's harness!!!
If anyone could answer this for me that would be great! :P
08-04-2012, 04:33 AM #2
I am not an expert but I think that any w58 is the same, the bell housing for the 22r or 22re (in the Celica) is different the shift fork is on the opposite side. I also think there is only one wire on the Manual ..the reverse light. However, If you are using your same ECU (after the Transmission is Switched) then you must make it think the Automatic is still there and in Park or Neutral or it will not send the signal to start. So I guess you use a jumper on those wires to do that
I have a W58 from an 85 Celica GT that I am going to put in some day so I hope my information is correct about all W58s are the same.
08-04-2012, 05:04 AM #3
Junior Member
- Join Date
- Feb 2012
- Location
- Fairfield, CA
- Posts
- 23
so since im getting a w58 for the 22r... but am changing the bellhousing to the 7m's... I should be okay for the most part?
08-04-2012, 05:43 PM #4
Only difference between W58's is the shifter locations changed throughout the years, and bellhousings/gearing was different, IIRC. Change the R bellhousing on the Celica transmission to your M bellhousing, and you're set to go.
'82 Supra L, '85 Supra P, '84 Supra P, '79 Celica ST, '89 Mazda RX-7
08-04-2012, 06:36 PM #5
Yup,shift towers are different,depending on model, year, from what I've read.
"This car is so loud , I heard you before I saw you!" said the nice policeman.
08-04-2012, 10:18 PM #6
You will be fine, Im running a Celica W58 in my Supra. All I did was swap the bellhousing. I also used the fork cause I didnt want to pay for a M series one at the time. There was only a very slight length difference. But when I put the trans in, the slave cylinder piston was at a weird angle. Two spacers on the slave cylinder bolts corrected this, and Ive put over 14,000 miles on the setup since swapping it last year.
1984 Supra P-type: 5MGE/W58 Swap/4.10 LSD. Cressida BBK. 5MGTE project soon.
1985 Celica GTS 'Vert: 22RE/W58 Swap/Restoration project/daily
1987 4Runner Turbo: 22RTE/Auto. Digital Dash. Inclinometer. BHG. To be running someday.
