Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    May 2012
    Charlestown Indiana
    279
    Replacing blown head gasket and run into a problem
    Alright guys, I have just had to do a head gasket replacement and I almost have it all put together. I run into a problem though while testing to see if this car will run and I did everything right. When I try to start the car it will try to start and get to abot 1k rpm then die instantly. If I mess with the throttle it will kind of stay alive for maybe 5 seconds longer then die. Also if I put starting fluid into the intake it will start up run to about 3k rpm and die. So it sounds a lot like I am not getting any fuel but I am just wanting to verify on what I should check for first. I have about 3 gallons of new fuel in the car. Should I just go ahead get under the car to see if the fuel pump is pumping fuel? Could it be a vacuum leak somewhere? Or could it be anything else? I had the car set at tdc and the distributor pointing at num 1 cyl, all new plugs wires and distributor cap. Kind of at a loss as to where to really start looking since there could be many possibilities.
  2. #2
    May 2012
    Charlestown Indiana
    279
    I may of actually of found out the issue. Or another issue. My dumbass forgot to tighten half of the intake bolts so obviously I have a huge vacuum leak. But is there an easier way to get these damn bolts in? It took me half an hour to turn 1 bolt 1 revolution on 1 of the top bolts. And the bottom ones I am sure will be even harder to get to. Anyone got any suggestions on an easier way to get these things tightened?
  3. #3
    Oct 2006
    Georgia
    5,157
    Might sound like a smartass question, but it isn't. Did you plug up your afm? I forgot to once.
    '82 Supra L, '85 Supra P, '84 Supra P, '79 Celica ST, '89 Mazda RX-7
  4. #4
    May 2012
    Charlestown Indiana
    279
    Yeah that is plugged up I am pretty sure it is probably because of the vacuum leak it is just hard as hell to try to get to these damn bolts on the intake lol. If I can finally get them back on I will try again to see what happens
  5. #5
    Jul 2003
    Lake Mills, Wisconsin
    3,411
    While you're at it, make sure you bolt down the engine wiring harness ground connection to one of those bolts on the intake manifold.
    Dave Harrison
    '85 Mark2 7mgte 5sp Isis
    '85 Mark2 7mgte Auto Athena
    '85 Mark2 7mgte 5sp Gaia
  6. #6
    May 2012
    Charlestown Indiana
    279
    Will do. These damn bolts are annoying the hell out of me lol. Especially the ones on top
  7. #7
    Apr 2012
    Hayward CA
    75
    Yeah its the intake bolts, my inexperience led to me forgetting to reconnect my intake after replacing my heater hoses and if the mafs isn't reading the proper amount of flow, it'll shut the car off.
  8. #8
    Nov 2004
    Graham, WA
    5,104
    Are you trying to put the intake back on as one piece? It is much easier bolting just the lower intake in the head, and then bolting the upper intake to the lower.
    -Chris
    1983 Celipra GTS:
  9. #9
    May 2012
    Charlestown Indiana
    279
    Yeah I was installing it in 1 piece. Everything is basically hooked up already just got to get these damn bolts in. After that I am thinking it should be good to go. If it is easier to do it as 2 different pieces where are the bolts located to be able to take the upper part off? Also would there be a gasket there that I would need to replace if I went that route? May have one in the head gasket kit I have but not positive on that.
  10. #10
    Aug 2008
    baltimore
    3,122
    Quote Originally Posted by 83CelWA View Post
    agree. and yes there is a gasket in between them.
    Edgar M.
id=a6141150">
