Results 1 to 6 of 6
    Nov 2009
    Phoenix
    16
    WTB: fuse block connectors
    My engine fuse block melted. I was able to find another fuse block, but I want to replace the connectors on the wires that were connected. I can't source either the wire harnesses or the connectors themselves.
  2. #2
    Toronto area, Canada
    1,532
    There were slight differences between years. What year is your car?
  3. #3
    Nov 2009
    Phoenix
    16
    Forgot that part, it's an 82 P-type.
    Quote Originally Posted by Dean View Post
  4. #4
    Mar 2005
    Santa Cruz, Ca. 95061
    3,069
    Should be same as 83, I'm guessing. I do have some blocks around. PM me, include cell.
    "This car is so loud , I heard you before I saw you!" said the nice policeman.
  5. #5
    May 2005
    Far East Bay, Dublin, California.
    1,520
    Is this the block you are talking about??
    I cut the wires before the connectors under this one if it halps.
    PM sent
  6. #6
    Nov 2004
    Graham, WA
    5,079
    Connectors are the same between all 82 to 85 celicas and supras. Even the fuse blocks are the same, just the difference in the label on the cover and what spots in the fuse block are used.
    -Chris
    1983 Celipra GTS:
id=a6141150">
