Results 1 to 8 of 8
Thread: drug it home and made it run
08-15-2012, 09:33 PM #1
Member
- Join Date
- Jul 2012
- Location
- mississippi
- Posts
- 40
just drug in an 82 l type with a 5 sp the inside is fried ! and other mechanial prolbems the same night i drug in an 85 celica gts with low miles only problem is an idiot under the hood im thinking about using the gts interior ''like new '' ive read that fire wall back its the same car so im hoping i can salavage sum good stuff switches ect and wats that ?!? a complete lock set real only 1 key that works every thing ??? open to any and all thoughts about interchangeable parts and the gts is a parts car no papers
08-16-2012, 01:18 AM #2
I think you're right about the parts from behind the firewall being interchangeable. I was lucky enough to find a complete lock set, including ignition lock cylinder, with the key, from a celica gts at a junk yard and it's now on my car. My car also has a window motor from a celica gts. Any pics?
08-16-2012, 08:29 AM #3
I am using the the rubber center counsel lid from a gts. Seems to hold up better then the foam. The interior looked almost identical to the supra's.
Matt K.
08-16-2012, 07:35 PM #4
Member
- Join Date
- Jul 2012
- Location
- mississippi
- Posts
- 40
im thinkin it should work ill know for shure shortly i cant help but wounder wat other parts will swap the gts has a tight clutch while the supra has a soft pedal and newer slave cl so im gona take a look see if the master wont swap out along with switches worth a try im on a budget
08-17-2012, 07:49 PM #5
Member
- Join Date
- Jul 2012
- Location
- mississippi
- Posts
- 40
working on the pics
08-18-2012, 12:14 AM #6
On the center console, there is a temperature sensor at the rear (next to the little fan). I have no idea if it is in the Celica. It is essential for climate control in the Supra. Unplug it and you get constant full heat regardless of any setting you select on the panel.
84P - Primer (faded Lt Blue Metallic) - bought March 5, 1984
83P Auto Daily Driver - Gunmetal Grey - acquired Nov 2007 - Recovered from the dead
82L White - ~44,000 miles Garage Queen
Original Owners List
Under 100K Miles List (starts post 25 - can't update at present)
2012 PNW Supra Events List
82 Vacuum Line Diagram Coloring Book
08-18-2012, 09:37 AM #7
Member
- Join Date
- Jul 2012
- Location
- mississippi
- Posts
- 40
good to know
08-18-2012, 11:01 PM #8
Member
- Join Date
- Jul 2012
- Location
- mississippi
- Posts
- 40
ok today i learned the head light relays swap same part numbers headlight switch ran a diff color code and carried 1 less wire but i cured my funky head lights !! so im gettin some of my money back out of it !! now if i can get the foglights to come on b4 the head lights id be thriled !
ill keep ya posted about wat i find to be swapable
