Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Sunroof
    Aug 2012
    Prattville, AL
    39
    Sunroof
    Sunroof functions like it's suppose too, but doesn't seal flush with the roof. What's the deal yo? Wore out or what?
  2. #2
    Aug 2008
    baltimore
    3,091
    pics...yo!
    Edgar M.
  3. #3
    Aug 2012
    Prattville, AL
    39
    How do i post it on a thread?
  4. #4
    Nov 2004
    Graham, WA
    5,076
    Read the sticky in the pictures area.
    As far as the sunroof, does it move up at all, is just not enough to seal.
    -Chris
    1983 Celipra GTS:
  5. #5
    Aug 2012
    Prattville, AL
    39
    it goes up and you can hear the motor start squealing (sounds like it's saying "woah, that's enough i'm all the way up") lol but its just not flush with the rest of the roof. it just sags on the back end.
  6. #6
    Aug 2012
    Prattville, AL
    39
  7. #7
    Aug 2012
    Prattville, AL
    39
    There. That's all the way up.
  8. #8
    May 2005
    Far East Bay, Dublin, California.
    1,518
    I see.
    It looks all wacked out.
    There's something wrong, there must be rust on the track too.
    Looks like someone sat on it or climbed up on your roof.
    It needs to be adjusted, if that's possible.
    There are "U" shaped spacers that are used in normal installs.
    You need to look at your rear mount brackets, yours might be rusted out.
  9. #9
    Aug 2012
    Prattville, AL
    39
    Yeah a bunch of dumbasses owned this before me. Nobody knows how to take care of these fragile pieces of art. We will though. Anyway where are these U shaped spacers you speak of?
  10. #10
    Oct 2003
    Montréal, QC
    5,676
    The u shape spacers are on each sides, top of pic above.
    I would not be surprized that you have rust under the fix part of the roof, which prevents the mobile part to raise high
    enough to seal properly.
    Read the section in the TSRM of how to remove and adjust it:
    http://www.cygnusx1.net/Supra/Librar...aspx?S=BO&P=36
    -Jocelyn
    P85-6MGE SDR(HKS kit c/w IC and F-Con in a box ) 225KKm, NAL seats, 2.5 Brullen, ACT clutch, LJM, SS lines, Trip Computer. EuroH4 + PIAAs
    P85-5MGE SDR had 439KKm (for 17 years my daily runner, RIP...)
    2002 E39 ///M5 LMB
id=a6141150">
