Results 11 to 16 of 16
Thread: Sunroof
    Kearney, Missouri (home of Jesse James)
    259
    It's been sat on or had a lot of weight applied in the past. Thats the exact same way mine is and it was just that the previous owner sat his young kid on it.
  2. #12
    Jan 2006
    Clarkdale
    744
    When you remove the inside cover(maybe just the plastic switch cover?) I think you can get a good look at the motor / drive mechanism. In think it's possible to put a large Phillips screwdriver into an the main drive spool (if there is a name for it, as it's a 10mm bolt maybe) to adjust the travel and closing. I'm too lazy to search for the thread. Kinda obscure. I had to do it as a final step afternreplacing antrack. It is probably plain as day in the trsm. Been a few years, and I no longer Recall...
    Doh--like he posted right above...sorry for not reading
  3. #13
    Jul 2007
    Chicago
    1,496
    See my thread - info starts at post # 22 http://www.celicasupra.com/forums/sh...nce&highlight=
    Tom - 83 P-Type, 5 spd, Terra Cotta, 108K, Chicago
    97 528i, 75k
    91 CRX.Si..114K
    84 Supra.P.125k..sold
  4. #14
    Sep 2006
    Southern MD
    783
    mine is the same way, just one of those things i haven't gotten around to fixing yet. it also leaks so i need to tear it down anyway.
    nice pics thread rex!
    - Black 85 P-Type 7M-GTE Project
    - 01 Dakota CC 4x4 4.7L 5spd, my DD
    - 06 4Runner Sport 4wd v6
  5. #15
    Mt Vernon, MO
    2,063
    Before you do anything else, remove all the rust and dirt packed into the very front of the track and clean the track real well. You shouldn't need to add shims or mess with the adjustments except during an install, and doing so now just addresses the syptoms and not the problem. The back of the sunroof lifts a lot as the sunroof travels the last 1/8" of track that is probably full of rust and debris right now.
    Jan. 1982 Blue 'P' type - DD, 6MGE intake/exhaust/17"SquareWheels, etc.
    1982 Terra Cotta 'P' type - 1UZFTE slowly progressing (high comp/low boost corner carver)
    1983 Black P - Rust Weight Reduction Mod :P +400k and in donor status
    1984 Red L - Fixing to make a come-back!
  6. #16
    Sep 2006
    Southern MD
    783
    mine sags in the front only on one corner
