Results 1 to 5 of 5
08-30-2012, 07:08 PM #1
so my clutch master cylinder Is shooting fluid onto my fresh kicks haha
So I just ordered my clutch master cylinder And I have a 2hour wait any helpfull tips on replacing it?
08-30-2012, 08:40 PM #2
Prime it with fluid. If its takes you longer then 30 minutes. You're doing it wrong.
Matt K.
08-30-2012, 11:45 PM #3
I found it easier to take the clutch master loose from the firewall first and then unbolt the hard line, giving it some wiggle room. Other than that it's pretty straight forward.
08-31-2012, 12:11 AM #4
Bench bleed it first. Get a new gasket if you want. Make sure you buy the correct one, some come with 1 stud and some come with 2 studs.
If your clutch master cylinder went out your clutch slave cylinder will probably go out soon too, might want to also replace that. You can also get a stainless steel braided clutch line from RabidChimp or Raptor Racing.
Might want to consider getting AISIN or Toyota brand for your clutch master cylinder.
http://www.celicasupra.com/forums/sh...orth-the-price
08-31-2012, 08:11 PM #5
Good info guys thanks,, I got it in last night, It was $25 from advance auto parts, I just gotta ajust my pedal now
