Results 1 to 10 of 11
09-13-2012, 07:44 PM #1
CelicaSupra.com Member
- Join Date
- Aug 2010
- Location
- Los Angeles
- Posts
- 146
Oxygen sensor/s how many? How to replace?
How many oxygen sensors does my Supra have 1984.
Is it just the one by the exhaust manifold?
I see a thick needle like thing sticking out, with a wire BUT....... that wire isn't connected to anything -____-
would that explain my 12 - 13mpg?
Do you guys recommend any specific o2 sensor brands? Car is stock, with no mods and no intentions of anything other than keeping it running strong, and maybe a CAI & exhaust.
How to replace?
Any stickies with pics on this or something? Or is it a basic screw in, screw out?
Thanks a lot
Check it out, been driving a year like this
09-13-2012, 08:13 PM #2
- Join Date
- Aug 2011
- Location
- Salem, OR
- Posts
- 274
Pb blaster is my only advice
1983 P-type auto two-tone red/black "Alouqua" 11/25/11 R.I.P. Stolen, totaled, irreplaceable.
1984 P-type auto white "Artemis" 11/29/11- 6m Power.
"When Alouqua died, the music stopped playing..."
09-13-2012, 08:29 PM #3
Any single wire o2 will work. Ya, that wire is broken. I think you'll find the other end closer to the passenger headlight direction. Make sure you have the plug end for the sensor. Sometimes when you buy it, it won't have the plug end on it.
86 Black MA67: 87 7M, 300hp, no shit! 84 Brown MX63: It's a Dork, not Donk!
09-13-2012, 09:18 PM #4
Just the one sensor. Go with a bosch or NTK. Get the engine hot by running it for 10 mins. Then slip a socket over the old sensor and turn that bitch out.
Matt K.
09-13-2012, 09:28 PM #5
- Join Date
- Aug 2010
- Location
- Los Angeles
- Posts
- 146
Thanks guys.. I'm looking for that other end of the o2 so I can change it tomorrow.. but I have no clue where it's at.
What is it next to? Or if anyone has a pic, I'll love you forever lol (:
09-13-2012, 09:50 PM #6
has anyone ever redone a wire?? mine is a little on the cracked side so I was thinking of rewiring it.
09-13-2012, 09:58 PM #7
It's just a single wire sensor as said before. Just cut away the old wire from the sensor and splice in a new wire. Or just get a new sensor they are cheap enough.Cover it with a heat resistance tape/sheath.
Matt K.
09-14-2012, 01:33 PM #8
The old one had the connector fall off his old sensor. But the plug comes from the harness that is on the passenger side of the engine bay. Look for it near the frame rail, look for wires hanging. Probably closer to the headlight. Also it is a two bolt flange, the studs won't likely strip or snap, but having it hot will help I'm sure.
09-14-2012, 03:55 PM #9
Just replace. My NTK Japan one from napa was like 30 bucks lol last one in stock
1982 Terra Cotta P-Type
Need boost...
09-14-2012, 09:52 PM #10
I thought on the Supra it is held in by two bolts, not a screw in type. Am I missing something? Mine is an '82 if that matters. I have a new one that needs to go in soon.
Bad decisions make the BEST stories.
1982 Supra P-type
1982 Specific TSRM's
Wiring Diagrams http://www.scribd.com/doc/44033354/1...iring-Diagrams
Emissions Repair Manual http://www.scribd.com/doc/44033268/1...r-Manual-5M-GE
Air Intake System http://www.scribd.com/doc/44033286/1...-FI-46-Thru-52
