Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Sep 2012
    Maryland
    16
    2jzge x73 cressida (has fuel, has power, no spark?) Please help!!
    Ok so pretty much ive got an x73 with an auto 2jzge from a jzs147 gs300 (not sure of year). I have power to all things necessary i.e. Ignition coil, ignitor, fuel pump etc... Now my problem is i do not have spark. I've checked over my wiring numerous times and ive also checked to see if i've missed any grounds, which i have not.
    *Not to mention that my engine harness and ecu are from a Cali spec sc300 (also unsure of year) if that makes any difference.
    I followed this wiring diagram:
    http://forums.nicoclub.com/official-...m-t535830.html
    Can someone please shed some light upon this situation?
  2. #2
    Aug 2008
    baltimore
    3,123
    did you bypass the NSW???
    Edgar M.
  3. #3
    Sep 2012
    Maryland
    16
    Quote Originally Posted by zuprax85 View Post
    By bypass do you mean splicing pins 76 and 77 together? the STA and NSW pins?
  4. #4
    Sep 2012
    Maryland
    16
    Also, the car turns over...but just no spark.
  5. #5
    Aug 2008
    baltimore
    3,123
    yeap 76 and 77 to the STA circuit of your car.
    Edgar M.
  6. #6
    Sep 2012
    Maryland
    16
    I dont understand. Could you elaborate?
  7. #7
    Aug 2008
    baltimore
    3,123
    Edgar M.
  8. #8
    Jan 2006
    chicago, illinois
    594
    if his car is cranking, the nsw is out of the equation already,
    check ecu grounds, check for voltage on the harnesses, tps / afm connectors, check for power on the ignition coil connector, make sure voltage is everywhere,
    5M-GTE 86 5sp cressida certified used toyota edition
    www.cressidaforums.com
  9. #9
    Aug 2008
    baltimore
    3,123
    that depends how he has the starter circuit hooked up, 2jzge starter wire is built in the engine harness.
    Edgar M.
  10. #10
    Sep 2003
    De Pere, WI
    1,889
    Where/how is the ignitor mounted? When I first did my swap I didn't realize that the ignitor grounded through its case, I had it zip tied (I know, I know) to the underside of the intake manifold. Make sure it is tightly bolted to the fender, or you have a good ground wire attached to it.
    Supra-less.
    Empty Spot in the garage.
id=a6141150">
