Results 1 to 6 of 6
    Apr 2003
    San Jose, CA
    150
    eibach springs and kyb agx adjustable shocks set up
    hi, anyone experience with eibach spring with 2 top coils cut on fronts and one coil cut on rears?
    is this gonna bottom out the mr2/focus kyb agx???
    kyb agx are shorter stroke shocks compare to tokico right?
    thank you
    ndt
  2. #2
    Greenville, SC
    11,673
    You won't bottom the mr2 agx strut out any sooner than stock, so long as you spacer them from the top of the strut tube, rather than spacers under the bottom of the strut insert.
    --billyM
    Blue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
  3. #3
    Apr 2003
    San Jose, CA
    150
    so 2 coils cut from front eibach spring is not a problem with agx.??
    i think it gonna lower like another half of inch or an inch.
  4. #4
    Mar 2004
    Houston
    1,197
    honestly, i would try one cut at as time, install it, drive it and see if it sits in at where you like it...if not take it off and cut again. I know its the harder and more tedious step, but once you cut more than you need, you can't go back.
    Sorry I don't have the eibachs up front, only GC coilovers, but i do have them in the rear, and not cut, which is to my liking.
  5. #5
    Greenville, SC
    11,673
    I took one coil out of the closer progressive section of the front eibachs and found it to be plenty of drop for my liking. As johnnyq said, cut a bit at a time....
    --billym
  6. #6
    Apr 2003
    San Jose, CA
    150
    thanks guys
id=a6141150">
