Results 1 to 8 of 8
    Jan 2012
    Chula Wanna... its in San Diego
    40
    help!!!!.... tranny id!!
    Its an r series but is it an r 154? What bellhousing is this? Got to figure it out by monday morning. before I drive back home!!!
    I hope this worked as I am posting from my stupid(smart) phone!
  2. #2
    Jan 2012
    40
    Little more info.. it gas a gear driven speed sensor. The guy who has it told me it either. Came out if a supra or a truck but doesnt seem to know much about it. He said the guy he got it from was an importer and that he thinks it came from japan.. It doesn't have a shifter with it but Iwas able to slide it into 3rd and forth with the exposed linkage. Yea.. I want my computer! Please help me ID this or point me to someone that can! Thanks!
  3. #3
    Nov 2004
    Graham, WA
    5,076
    Looks like an r151 out of the Toyota trucks.
    -Chris
    1983 Celipra GTS:
  4. #4
    Jan 2010
    Pittsboro, NC
    1,577
    ^ what he said. were any of those sold in 2x4's though? i thought the R150's had a transfer case? or is that just one of them?
    The Supra is gone... What a fun project!
    Living the Wagon Life! 86 X72.
    New family member, 89 MX83. (temporary DD)
  5. #5
    Aug 2008
    baltimore
    3,095
    looks like it came out of a truck, you can see the fork and starter are on the wrong side, not sure if this one is a r151, like ^^^^he said, those r150-r151 should come w a transfer case and the shifter in a different spot,
    Edgar M.
  6. #6
    Jan 2010
    Pittsboro, NC
    1,577
    either way though, you should be able to bolt on a 7m bellhousing and RocknRoll! those are good transmissions, becoming rare too!
  7. #7
    Oct 2006
    St. Cloud, MN
    2,852
    Yeah, came from a 2wd Toyota truck, most likely a one ton 2wd with the 3VZE V6. Yes you could bolt an R154 bellhousing onto it, but:
    1) Would the input shaft be the correct length? (I've heard there are different lengths)
    2) Would the gearing be suitable for your application, since the gear ratios are lower than the R154?
  8. #8
    Jan 2012
    40
    Thats what I thought. I told the seller what he has but hes pretty convinced he has a r154. Thanks all for the help. Its too bad... the price was right! As you said the gearing would be to low...mk2's are already geared to low for freeway speeds.
id=a6141150">
