Results 1 to 5 of 5
10-01-2012, 08:21 AM #1
can u put a ra65 irs into a 4 link ra60????
I have a 83 Celica with a 4 link rear end I also have a extra independent rear suspension out of a 85 Celica would anyone have any idea if I could put the independent into the car that has a 4 link
<€¥><€¥> AUDACIOUS<€¥><€¥> UNRULY UZ'S<€¥><€¥>
10-01-2012, 09:27 AM #2
Not easily, the body is different. If you want to cut the car up and weld in a new inner structure sure.
10-01-2012, 04:34 PM #3
Go look on celica-gts.com/forums about the info on trying the swap. But in short, you would pretty much have to cut 2 cars in half and weld the opposite halves together.
-Chris
1983 Celipra GTS:
10-02-2012, 01:41 AM #4
And after all that hard work you'd also end up with only a mildly better, if not worse rear suspension setup. If you're going to go through all of that that hassel might as well put a good IRS in from another car
Black 86 mk2 Project Car
Terry's 82 Auto DD all original 5m 600k km KING
Have an 85/86 Double Spoiler? Help Raptor's Double Wing Spoiler Reproduction Seal Kit become a reality!
10-04-2012, 02:47 PM #5
Sweet thanks guys that what I though because the Toyota cressida is the same way the wagon has a different pan than the sedan so u can't exchange the IRS fron one to the other without cutting it but ya crap lol thanks again for all the great info ill post pic of my car soon
