Results 1 to 9 of 9
    Jan 2006
    Riverside, Ca
    2,105
    7mgte gas mileage. Help me solve it
    My car gets absolutely horrible gas mileage. I took a trip yesterday that was 220 miles. I had cruise set and it sat at 70mph the whole way. I didn't even get into boost once on the trip, as this was sort of a fuel mileage test. My AFR's are right in between 14.6-15.0 at this speed. I originally thought it was just the tune, but it's not obviously. 17.9 mpg was all i got.
    Hopefully you gentleman can help me figure this out.
    I checked the codes, and these are the results:
    21: o2 sensor
    34: turbocharger pressure
    43: starter signal
    52: knock sensor
    I'm going to start with replacing the o2 sensor. Does it matter what brand I get? The price ranges from $17-108. Big range.
    The rest I'm not sure about. I've researched a bit and it seems the knock sensor wiring fails a lot, and that may be my code 52 problem. Code 34 and 43 I'm completely stumped about.
    Ideas?
    Austin Easley
    1984 Light blue Mkii
  2. #2
    Aug 2009
    Media pa
    1,250
    The 02 and knock sensor code is enough to cause bad milage.
    Matt K.
  3. #3
    Oct 2003
    South Bend, IN
    441
    I agree with Matt....fix those 2 codes and report back. On a recent trip in mine I averaged 27.5mpg, with hitting boost a few times. Only difference was I had the cruise set at 64.
    FLYGFSH
    "Life is too short to drive ugly cars!"
  4. #4
    Aug 2010
    Colorado
    843
    That's really bad :O my my 4000 pound 4runner gets 25 with a 1j
    82 L Type
  5. #5
    Sep 2006
    Southern Oregon
    370
    Well what gears do u have? Also if there's any exhaust leaks pre wideband, including pre turbo, that will throw your readings to the lean side, and your tuning would compensate for that
    7mgte, p type convert w/ digi dash, w58 (for now)
    Drift/Drag/Street Build thread-http://forums.celicasupra.com/showthread.php?t=55431
  6. #6
    Greenville, SC
    11,666
    Quit driving like a hooligan!
    That said, you've got to get the codes fixed, especially the knock, but otherwise get a wideband and monitor VF outa the ECU.
    --billyM
    Blue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
  7. #7
    Auburn, WA.
    5,753
    Theres a good chance I will be in Portland the weekend of Oct 27-28. I can help you dial in VF, if you have some free time then.
  8. #8
    Jan 2006
    Riverside, Ca
    2,105
    Replaced both knock sensors and did the knock sensor rewire.
    Replaced the o2 sensor.
    Not throwing anymore codes. But still getting at most 19mpg. I had the car professionally tuned. 339hp, 323tq. The gas mileage isn't in the tune.
    No more fuel cut either.
    3.73 gears.
    Any other ideas?
    Austin Easley
  9. #9
    Greenville, SC
    11,666
    New plugs, cruise for a few hundred miles, check color...
    --billyM
id=a6141150">
