Results 1 to 10 of 15
Thread: walbro 255 install HELP
10-10-2012, 12:15 AM #1
Member
- Join Date
- Sep 2011
- Location
- Lakewood, CO
- Posts
- 70
Now I'm sure I'm stupid but, I'm trying to install this walbro 255 I got from chimp and it only came with 2 barb fittings? What's up with that? I understand the one side but how am I supposed to get the pressure fuel line hose where the banjo type fitting was located? That will not work with a barb for sure.. help please I'm dumb =l
"Cheap, Fast, Reliable, pick two and thats what you get in a car"
10-10-2012, 07:50 AM #2
In-tank?
Dave Harrison
'85 Mark2 7mgte 5sp Isis
'85 Mark2 7mgte Auto Athena
'85 Mark2 7mgte 5sp Gaia
10-10-2012, 09:31 AM #3
Member
- Join Date
- Sep 2011
- Location
- Lakewood, CO
- Posts
- 70
Its an 82 sorry, so in line not in tank
10-10-2012, 11:37 AM #4
I think you cut the banjo's off so you can slide in the barbs and hose clamp. I could be wrong though. Check with Aaron.
86 Black MA67: 87 7M, 300hp, no shit! 84 Brown MX63: It's a Dork, not Donk!
10-10-2012, 01:12 PM #5
Member
- Join Date
- Sep 2011
- Location
- Lakewood, CO
- Posts
- 70
I thought it was pressure line but it could be, anyone confirrm this?
10-10-2012, 01:24 PM #6
Member
- Join Date
- Aug 2012
- Location
- Midvale, Utah
- Posts
- 44
I'd like to know also!
10-10-2012, 02:49 PM #7
The pump is on the pressure line. The hose going to the tank is the feed line for the pump, and the one going to the motor is the pressure line. You could cut the banjo fitting off the rubber hose and use slide the barb in and clamp it. I'm pretty sure that would be how the chimp would intend it, if that is what he sent you. Check with him first if you are unsure.
10-10-2012, 10:44 PM #8
Sounds like you bought an in tank pump for an external setup?
82 7MGTE, W58, SP61/upgrded elbow, Spearco IC, P&P, 2.0MHG, VPC/SAFC2, LM-1 Wideband, Full 3in, TRD rear, Springs/Shox, Cold A/C, 85 deck
89 7MGTE, SP67 @ 18lbs, VPC/SAFC2, Spearco Front Mount, 550 inj, full 3inch exhaust
WANTED: KAMINARI/EREBUNI front lip
10-11-2012, 01:08 AM #9
See if the silencer threads on the output of the pump before you go cutting anything.
-Chris
1983 Celipra GTS:
10-11-2012, 05:18 PM #10
Member
- Join Date
- Sep 2011
- Location
- Lakewood, CO
- Posts
- 70
Silencer doesn't thread its a much smaller thread size, and nope it was the in line one because the in tank one comes with diferent hardware.. idk how this is supposed to work..
