Results 1 to 7 of 7
    Nov 2010
    Hawaii
    4
    Gauge fuse keeps blowing
    I have a 83 celica supra with 25k miles in mint condition, everything works flawlessly but for some reason it started blowing the gauge fuse. I've tried pulling the blower fan breaker, power window breaker and relay and it still blows the fuse. It seems to blow randomly, sometimes it can drive for hours without blowing and sometime only seconds. It seems to always blow when the car is warm and in reverse, I was thinking maybe neutral safety switch?
    Has anyone had a similar problem or know how to diagnose this?
    Thanks
  2. #2
    Jan 2011
    Cape Cod
    225
    Adding fuses
    You can try to wire in separate, new, in line fuses to each of the electrical parts that branch off from the fuse that blows , Then you will have a way of knowing which part is shorting out, I would try to repeatedly putting the car in reverse to see if you can narrow down the search. Carl H
    Quote Originally Posted by briand View Post
    Thanks
  3. #3
    Apr 2008
    missoula montana
    1,164
    what I would do is unplug things that you think are making that fuze blow and drive it around. Plug things in one by one to narrow down what it might be to. It is the easiest way to track whats going on.
    82' fresh paint 7mgte -___- 11k+ deep
    What am I doing currently?
    What kind of oil should you run?
    Lexus afm and 550cc injectors?
    Exhaust & Intake cam timing?
  4. #4
    Nov 2010
    Hawaii
    4
    I think it has to do with the reverse lights. If I put the car in reverse, even with the engine off the fuse blows. Where is the backuplight switch located?
  5. #5
    Apr 2008
    missoula montana
    1,164
    if its a 5 speed, im pretty sure its on the driver side of the tranny and its a round plug. try unplugging that and see if she doesnt blow
  6. #6
    Nov 2010
    Hawaii
    4
    Its a auto so It might have something to do with the neutral start switch/backup light
  7. #7
    Jul 2007
    Dallas Center, IA
    986
    I think I had the same issue a few years back in my 82.
    http://www.celicasupra.com/forums/sh...lem&highlight=
    Two wires were grounding out on each other, eventually it started smoking from the area; which was a dead giveaway..
    MegaSquirted 62mm 7m @ 20psi on 91 octane
    410whp/411ftlbs
    Build Thread
id=a6141150">
