Thread: Power lock relay help
10-12-2012, 10:18 PM #1
The power locks do not work on our Supra, and we are trying to resolve this issue. I've taken the entire door panel apart on both doors, and tested each power lock motor- both are functional, but I did notice a bit of corrosion on the power lock relay box. Popped it open and pulled the circuit board out, sure enough the thing is fried from water damage. Where can we get a new relay? None of the parts stores seem to carry it.
I did find this unit on eBay, not sure if it will work though. Does anybody know if they are the same?
http://www.ebay.com/itm/TOYOTA-SUPRA...sories&vxp=mtr
-1984 Toyota 4-Runner (Dads)
-1985 Toyota Celica Supra, 5M-GE 5 Speed (Bros)
-1989 Jeep Wrangler YJ (Mine)
-2006 Toyota Highlander (Moms)
10-12-2012, 10:32 PM #2
that link appears to be a part for a MKIII supra not a MKII
have a picture of the box out of your car?
will"Betty" 85 Supra. LJM front strut bar, custom rear bar, Addcos sway f/r, Tokico f/r, Eibachs springs, and full PST bushing kit, Cusco camber plates, RC intake w/custom cold air & K&N filter, JK short shifter, MKIII 10 blade radiator fan, SS break lines, RC SS clutch line, Russel quick bleeders, custom stereo.
"Karmen" 85 Supra. RC TB and intake. Bored out AFM, Magnaflow cat. soon new stock brake lines and muffler.
http://www.willdabeast.net
http://www.whitmansauto.com
10-13-2012, 12:41 AM #3
It looks exactly the same, don't have a picture at the moment. I've asked the seller if he could supply a picture of the face of the box, try to match up the numbers.
Was wondering if anyone around here has used one before out of a MkIII...
10-13-2012, 12:57 AM #4
I have this one.
PM sent.
10-13-2012, 10:13 AM #5
The door lock control relay is next to where the brake pedal assy attaches to the firewall, the relay you are looking at is the controls for the door. If you are not worried about being able to unlock both doors from the drivres side and do not have an oem alarm, the relay in the door can be bypassed with a little wiring.
-Chris
1983 Celipra GTS:
6M bored .50 over. 250cc injectors. Delta 272 regrind cams. Carter HF fuel pump.
Pacesetter header w/2.5" cutsom exhaust. Open air intake filter. 3" piping to TB. 65mm TB & ported AFM.
4:10 rear from Supra. BillyM shifter kit. Swapped most interior over to black. T3 camber plates.
935 Budget Coilover kit. KYB AGX struts. T3 Needle bearing upper perch kit. Eibach Sport rear supra springs. SF Ford TFI Performance coil.
Almost finished with the fiberglass hatch!
10-13-2012, 03:51 PM #6
The car has an OEM alarm, would rather put everything back to original than bypass stuff. Pretty sure this box is the cause, lots of corossion... Also, the power windows both work without the box.
10-14-2012, 01:21 PM #7
- Mar 2003
- Clifton NJ
- 2,520
Other uninspected things could be corroded/unoperating too
84 mt 6mge with intake, exhaust, suspension, brake, and wheel mods
85 mt 6mge stock
10-14-2012, 10:03 PM #8
I'm relatively sure its isolated to the drivers side door. The window regulator is done for so it doesn't seal properly against the window seals. I've checked the passenger side and under the dash, nothing else is really coroded or showing signs of water damage.
01-30-2013, 01:18 PM #9
- Apr 2012
- Fresno, CA
- 6
Is there anyway to remove that relay and replace it with another that was found at the junk yard?
-HeyItsRaul
01-30-2013, 06:04 PM #10
The box just plugs into the harness inside of the door, so it could absolutely be replaced with another unit.
