Results 1 to 3 of 3
    Nov 2010
    Hawaii
    4
    Where is the backup light switch on a auto trans
    I have a 83 L-type auto and can not locate the backup light switch, is it on the transmission or in the console?
  2. #2
    Apr 2005
    Charleston, SC
    3,780
    It's on the transmission.
    David H
    85 Pos, 5.3/w58 swap
  3. #3
    Nov 2004
    Graham, WA
    5,076
    It's the same switch as the nuetral start switch, just look on the pass side of the transmission about halfway down the transmission body.
    -Chris
    1983 Celipra GTS:
id=a6141150">
