Results 1 to 10 of 11
Thread: Williamb82 crank trigger wheel
10-18-2012, 09:16 AM #1
Junior Member
- Join Date
- Aug 2010
- Location
- new york
- Posts
- 3
Can anyone here give me an idea where to source one of these or something like this trigger wheel.
10-18-2012, 11:54 AM #2
they sell universal ones on diyautotune.com. kinda why i stopped ordering them. the universal ones are thinner but still work.
http://www.diyautotune.com/catalog/t...eels-c-48.html
though if your on a 7mgte, i highly suggest using the stock cps instead. much cleaner look imho. im about to switch my 36-1 setup for a modded cps.william
10-18-2012, 01:58 PM #3
CelicaSupra.com Member
- Join Date
- Jul 2007
- Location
- Dallas Center, IA
- Posts
- 986
What he said.
Couple links for reference:
http://www.celicasupra.com/forums/sh...ghlight=johnb7
http://www.celicasupra.com/forums/sh...29-my-7MGTE-82
10-18-2012, 03:07 PM #4
btw, reason i went with the 36-1 back when i did is because they didnt currently have the toyota trigger wheel setup in ms2. now they do. you can run it unmodded as 24+1, or mod it to 24-1, or 24-2 and set to crank trigger 12-1. lots of possibilities now. technically you can do the same with a 5m dizzy.
william
10-18-2012, 05:36 PM #5
- Join Date
- Apr 2009
- Location
- blank
- Posts
- 234
Will, I see that you are running the 24-2. What teeth #'s did you remove?
10-18-2012, 06:21 PM #6
i havent removed any yet. ill prolly order the stuff this week to switch it over. gonna play with the firmware before removing any teeth. might only remove 1 tooth to make it a cam 24-1.
found info on it here
http://saturnwiki.net/wiki/index.php...quirt_II_7MGTEwilliam
10-19-2012, 07:12 AM #7
Junior Member
- Join Date
- Aug 2010
- Location
- new york
- Posts
- 3
10-19-2012, 08:24 AM #8
if the cps internal oil seal is leaking, then rebuild it.
http://www.celicasupra.com/forums/sh...ht=cps+rebuildwilliam
10-19-2012, 11:06 AM #9
Junior Member
- Join Date
- Aug 2010
- Location
- new york
- Posts
- 3
I also considered putting a 4" 36-1 wheel on the dizzy as well in the past with a GT101 Honeywell sensor
. Do you think that would have worked....the designer of the Wolf ECU says it probably would, but that the crank would offer a better signal read.
10-19-2012, 11:41 AM #10
i dont think megasuirt has a 36-1 cam signal algorythm in place. a 36-1 crank trigger will work fine. its all in how accurate you want to be. is it neccessary? not really.
william
