Results 1 to 7 of 7
    Sep 2012
    Eastern Ma
    9
    WTB MKII Manual Swap Parts And Harmonic Balancer
    I'm doing a manual swap in my 86 Cressida; I need this stuff out of a MKII Supra, preferably an 85 I guess. Shipping to 02703. You can reply here or PM me. I'll keep an eye on this.
    I need
    Clutch pedal w/switch [and pigtail if possible]
    Brake pedal
    Clutch Master cyl
    Clutch line complete from MC to Slave w/clips
    Driveshaft
    Flywheel w/bolts
    Clutch w/bolts
    Cover under shifter boot [unless you know it won't work on a Cressida]
    Shifter boot
    I also need a good harmonic balancer.
    93 Celica Alltrac Turbo
    91 Hilux V6 4WD DLX
    86 Cressida
  2. #2
    Dec 2011
    Tulsa County, OK
    695
    I have a lot of this stuff, PM sent.
    1985 Supra Mk2 P Type, 2JZ transplant patient.
  3. #3
    Jul 2009
    Brooklyn, NYC
    1,214
    The MKII Brake Pedal, Leather Boot, and the Front half driveshaft will not work in a Cressida.
    You need a MKIII Supra brake pedal, just have to cut and reweld the brake switch tab on the other side, you need a front half driveshaft from a non turbo 5 Speed MKIII Supra. And the leather boot, no idea on that one. I havent found or heard of one thats a direct drop in.
    Ive 5 speed'd two X7s, worked on a 5 Speed X6 and was in the process of 5 Speeding my current Cressida. lol
    1984 Supra P-type: 5MGE/W58 Swap/4.10 LSD. Cressida BBK. Under the knife for the winter.
    1985 Celica GTS 'Vert: 22RE/Auto Undergoing resto and Engine/Trans/LSD swap
    1986 Cressida: 5MGE/W58/LSD. Supermonitor. AGX Rear. Daily Driven.
    1987 4Runner Turbo: 22RTE/Auto. Digital Dash. Inclinometer. BHG. To be running someday.
  4. #4
    Sep 2012
    Eastern Ma
    9
    Thanks for that info, I really appreciate it.
    I'll send you a PM tonite, gotta run to work.
    91 Hilux V6 4WD DLX
    86 Cressida
  5. #5
    Oct 2006
    St. Cloud, MN
    2,842
    Mk2 supras don't have a switch on the clutch pedal for a starter interrupt, so you'll have to fab a bracket yourself.
  6. #6
    Jul 2009
    Brooklyn, NYC
    1,214
    They have the switch for the Cruise cancel, you can wire that as a starter interrupt between the terminals on the neutral safety switch. This can also have your cruise completely functional again in a swapped car. But I havent read the FAQ in awhile to verify if this is all you need.
  7. #7
    Oct 2006
    St. Cloud, MN
    2,842
    Brilliant! I forgot about that, since the cruise stopped working in my 84 and I seldom used it before it broke anyway. That makes me wonder if that switch in a MK2 could be wired to a pair of relays, with one relay for cruise and the other for a starter interrupt. You could then wire up a switch in the starter relay wiring to bypass the relay and enable a remote start neutral safety switch to be wired in, to add a remote start system. It could even be done in a swapped Cressida, to truly have all the luxuries that the car is known for.
id=a6141150">
