Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 7mgte ecu
    Apr 2012
    quebec
    31
    7mgte ecu
    hi, i was told that a ecu with grey plugs goes with a grey conector and vice versa with yellow .my ecu is grey with 26p 16p 22p plugs, nomber 89661-14230a/t it is a 1988-89 ecu, for now every thing is ok, but here is were im confused, my engin harnest has (yellow) connectors for my ecu witch fit in the plugs (GREY),the seller said that the ecu is for this harnest.i look it up and there seams to be some kind of mis match in early 1988 and late 1988, i was wondering if all this is possible ,i heard somme bizare things about 88-89 7mgte, by the way i got a jdm engine, but never saw it run..
  2. #2
    Jul 2007
    Dallas Center, IA
    989
    Quote Originally Posted by toytoy View Post
    Pictures would help. I would also compare your ecu to the two different ecu's, google to find what it looks like. From what I remember and I've only seen one 89+ ecu, there's no way the post 89 plugs would fit in it. My guess is, if it fits... it's probably the correct ecu for the harness.
    MegaSquirted 62mm 7m @ 20psi on 91 octane
    410whp/411ftlbs
    Build Thread
  3. #3
    Spring Hill, Fl.
    13,962
    greay plug ecu/harness combos are year specific. must use an 89 ecu with 89 harness, must use 90 ecu with 90 harness, etc... yeloow plug doesnt matter. 87/88 can be mixed with no issues.
    william
  4. #4
    Feb 2004
    Calgary, Alberta, Canada
    2,038
    That being said, the actual plugs grey/yellow won't fit in the 'wrong' ECU as they are a different form factor. If the connectors do actually fit the ECU, give it a shot.
    '84 P-type, 5spd, torrid red, black/grey leather
    Built 7MGTE (JE's, ARP studs, MHG), BOSS STG4 60mm, AEM standalone, R154, 2 1/2" IC and 3" turbo back - the works
    Coilovers, ROH wheels, 4 corner BBK, Konis, ADDCO bars, PST bushings etc. etc.
  5. #5
    Apr 2012
    quebec
    31
    thanks,but stil a litle bit confused. ive seen on ebay ecu`s with the same plugs as mine but yellow. but if i plug the ecu will i kill something,or worst blow my ecu...
    and ecu with a conector on it like a power in is it for a specific year my ecu does not have that
  6. #6
    Apr 2012
    quebec
    31
    and ecu with a conector on it like a power in is it for a specific year my ecu does not have that.
    how do i know the year of my harnest
  7. #7
    Sep 2005
    va. beach va.
    256
    could check pin outs in the manual to see if same plugs have different pin placement. ie, pinn 22 on a 90 coulld be pin 19 on a 91. these are examples and not a reflection of actual pin placements.
    MY BABIES
  8. #8
    Feb 2004
    2,038
    The 86-89 and 90-92 ECUs have physically different plugs, so you cannot plug in the 'wrong' ECU. If the plugs fit in, it should work.
  9. #9
    Apr 2012
    quebec
    31
    how do i know the year of the harnest...
  10. #10
    Jul 2007
    Dallas Center, IA
    989
    Well...
    Quote Originally Posted by Funkycheeze View Post
    This will get you in the ball park,
    Quote Originally Posted by jtwhitehead View Post
    this will get you the exact year,
    Quote Originally Posted by Suprasaurus View Post
    this would clear up a lot of the confusion, get in you in the ball park, and possibly get you the exact year.
    410whp/411ftlbs
    Build Thread
id=a6141150">
