Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Feb 2010
    Walker, Louisiana
    314
    82 L type, how to know the right size spacer.
    I bought rims a while back and the cars stance has slowly started to annoy me. The back wheels are tucked well under the rear fender wells, about 3 1/2ins. That measurement is a guess. But do I just measure from the top outside edge of the tire, to the inside lip of the fender? I dont want to mod the body any, but I am guessing this should give me the proper distance I need so I can get spacers just under that distance so that the tires sit nice and flush. Is this the right way to do this? :l I am unsure, so I know my buddys here will tell me right from wrong!
    here is a picture so you can see the rear "Just click it to make it bigger, and then click it agian."
    Daily 82 L-type used to be terracotta...
    New project Red 85 P-type.
    Part cars: Silver 82 L-type, Red 82 p-type.
  2. #2
    Feb 2010
    Walker, Louisiana
    314
    Photos before I had the hatch painted black notice how its red. Yea I put that MK4 sticker on there...dont hate
  3. #3
    Oct 2008
    Tazewell Virginia
    242
    what offset are the wheels for starters, that will be the best place to start from in terms of spacer thickness
  4. #4
    Feb 2010
    Walker, Louisiana
    314
    17x7 all the way around, I didnt have money for anything else.
  5. #5
    Feb 2012
    SO SO CAL
    166
    those are some high offset wheels. if you get thick spacers you will also need et lugs.
    1984 Toyota Supra 5MGE
  6. #6
    Oct 2008
    Tazewell Virginia
    242
    rim size is not offset, those look like a +40 or higher, it will be on the box the rims came in.
  7. #7
    Sep 2010
    Toronto/Clarington
    965
    oh god yeah! those are high offset wheels (40mm offset or higher) you need low offset wheels, zero-20mm offset or lower.
    good god!! sell those to a prelude or 240sx kid.
  8. #8
    Auburn, WA.
    5,757
    Well, Tire size would help, as Height and width of tire will help us give you spacer specs, also. You can determine the offset by removing the wheel, deflating the tire, putting a straight edge across the back(mounting side) of rim, and measuring the distance between the straightedge, and the mounting pad. If those are 17x7 +40, that measurement will be close to 5 1/2 inches. Assuming a close to stock size height and width tire, you would need a 1" front spacer, and a 1 1/2 to 2" rear spacer. Heres a link to a 25 mm(1 inch) for the front http://www.ebay.com/itm/HUBCENTRIC-B...f0f912&vxp=mtrand a 38mm(1-1/2) for the rear- http://www.ebay.com/itm/OEM-HUB-CENT...f0f94f&vxp=mtr
  9. #9
    Feb 2010
    Walker, Louisiana
    314
    Yea I know they are horrible rims...I couldn't get any others :l and hearing other peoples thoughts about them. I wish I d never bought them. Tire size 215/45/17
    this is the exact wheel http://www.wheelfire.com/scontent/Wh...431-3&SKU=5678
    Also on here
    http://www.carid.com/mod-tech-wheels...ed-945543.html
    I like the way the rims them selfs look, but I hate the way they look on the car...
  10. #10
    Jul 2003
    Naples, Fl
    16,221
id=a6141150">
