83-84 engine swap
Results 1 to 10 of 10
    Member
    Aug 2012
    Washington
    54
    83-84 engine swap
    Recently I've had a lot of issues with my engine and got a great deal on a new one from a member of this forum. I own an 84 supra 5mge manual. The engine I got was for an 84 supra automatic. The problem I am running into is the input shaft of the tranny hits the back of the crank with about 1/4" before it would mount to the engine. I have spent the last 3 days looking for a thread that says anything about the crankshaft difference between auto and manual. I'm sure plenty of people have done a swap like this and has information on this. Thank you!
  3. #2
    CelicaSupra.com Member
    Feb 2013
    San Antonio Texas
    708
    are u using the tranny form u 5 speed supra?
    Dylan
    1985 toyota supra
    Build thread Hidden Content
  4. #3
    Member
    Aug 2012
    Washington
    54
    Yeah I am
  6. #4
    Member
    Sep 2011
    sarasota fl
    61
    u align the clutch?
    7mbhgte life= bhg and spun bearings
  7. #5
    CelicaSupra.com Member Mkeller316's Avatar
    Aug 2009
    Media pa
    1,592
    So the problem is that the input shaft is too far away from the block? If so then try switching the engine mounts around.
    Matt K.
    84 P type - retired DD stainless steel header, Rabid Chimp 2.5 exhaust. 2.5 all the way back to the muffler,kyb agx's 2jzge swapped Hidden Content
  8. #6
    Member
    Aug 2012
    Washington
    54
    The problem I am having is the input shaft meets the crankshaft with about 1/4" before the tranny mounts up. That's as far in as it will go before I would have to run it down with bolts (which I won't due, don't want to break anything on the bellhousing). I put a little grease in where the pilot bearing goes without the pilot in to see if it really meets. It went through all the grease and was pressed against the crank.
  9. #7
    Oct 2006
    St. Cloud, MN
    3,709
    Is it possible that the input shaft started pulling out of the transmission when you separated the old engine from the trans? You might be able to tap it back into the trans with a plastic dead-blow hammer or rubber mallet. There is NO difference between the crankshafts, so that isn't the culprit.
    Hidden Content
  10. #8
    Member
    Aug 2012
    Washington
    54
    Okay that's good to know. I was worried I was going to have to buy a new crank because I bought an automatic engine I had a feeling that the only difference was the wiring harness and transmission. Thank you!
  11. #9
    CelicaSupra.com Member 4SFED's Avatar
    Jul 2003
    Lake Mills, Wisconsin
    5,199
    what did you about a pilot bushing?
    edit: nevermind, I somehow skipped post #6 til just now.
    Dave Harrison
    current lineup and year acquired:
    '85 white Mark2 7mgte 5sp 1990
    '85 white Mark2 7mgte Auto 2009
    '84 maroon Mark2 6mge 5sp 2013
    '86 red Mark2 7mgte 5sp 2016
    '85 black Mark2 6m Frankenmotor 5sp 2017
    Hidden Content Originally Posted by cheappower82 Hidden Content
    Guess you have the magic touch; touch mine please?!
  12. #10
    Member
    Aug 2012
    Washington
    54
    So the problem I am having now is that when it all gets mounted up it locks up the engine and I cannot turn it by hand anymore. Looking at the old crank it looks like the input shaft has warn a groove in it and created a place for it to ride without hitting anymore. Not sure if that's normal, but certainly doesn't seem like it.
