IUZ wiring diagrams - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    CelicaSupra.com Member Peewee's Avatar
    Nov 2004
    West Aust, Perth
    577
    Go to lextreme.com and sign up to those forums.
    Anyone doing anything with a 1UZ should do that.
    UZZZ12 - ~350rwhp - 13.8@101
    Hidden Content
  3. #12
    CelicaSupra.com Member Jkm3141's Avatar
    Jun 2007
    Rochester, NY
    273
    1996 SC400 TEWD + Connectors
    Hey guys,
    I've been meaning to post this for a while. During the wiring portion of my swap last year, I subscribed to Toyota's TIS (online TEWD and TSRM for all post 1990 Toyota/Lexus/Scion). It only cost me 10 dollars for a single day subscription, and it gave me a rather clunky web interface to any OEM information for post 1990 toyota products. The only problem is the TSRM pages are all seperate PDF's, and can be time consuming to download every page. Generally TEWD's are a single PDF, with all supporting wiring info in separate PDF's.
    I am posting the complete wiring (TEWD) for a 1996 SC400, as well as the connector pin outs. This 'should' be the same as a non VVTI post 95 LS400 as well, but do not quote me, as I have never worked with that motor, and the ECU's might be different. I know for a fact this is quite different from the more common early 1UZ, as this is an OBD2 motor, it is MAF based, and is higher compression. I used this motor in my swap, hence having the wiring. I thought I pulled the TEWD for a 91 LS400, but I cant seem to find it. I also have all the TSRM pages for the 96 1UZ engine mechanicals if anyone needs them as well.
    Anyway, the links are as follows:
    http://frontiernet.net/~jkm3141/1996...Connectors.pdf
    http://frontiernet.net/~jkm3141/1996_SC400_TEWD.pdf
    These links should remain active as long as my mother still has the same ISP (no reason she will ever drop them. This is the most 'reliable' posting location I can think of as my website, Jkmcustoms.com, is never reliably online, as well as the content changes every other weekend.
    If anyone has any questions on the MAF based non VVTI 1UZ, I feel I am rather familiar with the wiring of these engines. Shoot me a PM or Email: jmeichle@gmail.com
    - John
    EDIT: If these links ever stop working and you need the PDF's, shoot me a PM. I will never delete them from my hard drives.
    Hidden Content
    Hidden Content
    **Sold to Suprafanatic*** so now I am supra-less
    SC400 1UZ-FE V8, LS400 oil pan + oil filter location, Phil Bradshaw's adaption harness, W58 using Phil Bradshaw's adaption plate, Howe Hydraulic Throwout Bearing, Peewee's Mounts, Modified SC400/LS400 manifolds, Dual 2.5 Inch Cherrybombs right off the manifolds, Rabidchimp's Walbro 255 Fuel Pump
    Hidden Content
  4. #13
    Nov 2004
    West Aust, Perth
    577
    Can I ask you to rename them as "1996 SC400 Connectors" and "1996 SC400 Overall EWD" ?
    It just makes it a lot easier if someone comes across these somewhere else in the future, so they know exactly what car/year they are for.
    Ta.
    Hidden Content
  6. #14
    Jun 2007
    Rochester, NY
    273
    Done.
    Hidden Content
    Hidden Content
    Hidden Content
  7. #15
    Nov 2004
    West Aust, Perth
    577
    Excellent, cheers.
    Hidden Content
  8. #16
    Oct 2008
    Redondo Beach, CA
    127
    give me a year make and model, and a guy i know can look it up for us
  9. #17
    Apr 2009
    blank
    258
    91 LS 400. Any luck with that?
  10. #18
    CelicaSupra.com Member CelicaDrifts's Avatar
    Feb 2010
    Vancouver Island Canada
    598
    http://www.lextreme.com/misc.html
    seems to have alot of info on this page.
    1984 Celica Supra - black - sunroof - 1uz project.
    1987 Suzuki Samurai - long wheel base - flat deck project - fully locked chromolly axles w/ 3 inch lift
  11. #19
    Feb 2010
    598
    Needing help with my o2 sensors. Wire colours are all different from the diagram, no matter what diagram I use... And not just those wires but everything is different colours.(maby because my 1uz came from a celsior?)
    I need a wire pin out of the o2 plug if possible! I even own a repair manual from Lexus and it shows no info on this.
    I have pinouts for my ecu.
