IF this is gonna be a sticky,this needs to be added.
Window motor replacement,adjustments,cautions.
https://www.celicasupra.com/forums/sh...t=window+motor
Some of window motor threads are out of date/not available.
Window adjustments. MARK it B-4 you move it.A little adustment is a LOT.
The guide rollers dry out and causes a squeal.
The rollers at the base of the window dry out,too.
Lithium grease is very good.
The Dorman replacement motor is excellent, but there are tips and tricks involved.
Use self locking "Nylocks 6X1.0 wherever you can,the stock ones rattle loose.
Yes,re-use the vapor barrier and seal it up with box tape,any holes you made.
ANY sticky requires photos.
