Transmission removal
Results 1 to 10 of 11
    Oct 2018
    Maryland
    10
    I am going to remove my trans to do a rear main seal and the TSRM says I need to drain my coolant, remove upper radiator hose and remove steering gear housing etc. At first glance it doesn't appear that all that should be necessary. Am I missing something?
    5,238
    Not at all. They also say to disconnect the negative battery cable. No reason to.
    With an automatic there are cooler lines.Big deal.
    Coolant is not involved at all with a transmission.
    A tail shaft "cork" is good to avoid a big mess.A plastic pill bottle may work,of the correct size.
    http://www.cygnusx1.net/Supra/Librar...Section=MT&P=3
    8,074
    No you don't need to do anything of that
    Oct 2018
    Maryland
    10
    Thanks for confirming I don't need to do all that, I was thinking it might be needed if you tilted the engine back.
    yea thats the page of the manual I was looking at, its not very uh... "verbose" lol. Emptied the trans so don't need worry about fluid.
    8,074
    Just make sure you have about 3 ft worth of extensions to remove the starter and upper bell housing bolts. You'll probably want to remove the stock fan if you still have the fan shroud.
    15,001
    Buy a 24-36in long extension, then you can use a socket and ratchet with the ratchet back by the tail housing after you remove the trans cross member to get the bolts out. Or an impact if you have a 1/2in drive extension that long.
    Black 84 7mgte/R154, MS2, truetrac, bbk, etc...soon to have 2jzgte and t56
    Blue 85 Beater. TRD Header, HKS Exhaust, custom 3in intake pipe, cone filter
    Black 86 Triple Weber 6m Eventually
    Rusty 85 Frankenstein 6M/w58 with DIYPNP
    Oct 2018
    Maryland
    10
    You guys didn't warn me about that top starter bolt, that guy is an a-hole haha. Got the trans out though.
    CelicaSupra.com Member mutantcolors's Avatar
    Nov 2016
    USA
    667
    We ended up double-wrenching the top bell housing bolts when we ripped my 5M out. Not easy but we got there.
    Attached Images Attached Images
    15,001
    Instructions for the starter are on this post.
    https://www.celicasupra.com/forums/s...l=1#post440870
    Oct 2018
    Maryland
    10
    Some good stuff in there, thanks! I did the starter from underneath, I see now that it would have been easier from above. haha
    Now to find the oil leak/leaks. I assumed it was the rear main seal, but the EGR seems suspiciously very oily. I might have to do all the seals in that area.
