Greetings from Alberta - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Junior Member
    Mar 2019
    Calgary, AB
    13
    Quote Originally Posted by Funkycheeze View Post
    Check out the alberta supra club on facebook - lots of members and a few mk2 parts hoarder types.
    Ew Facebook haha. Thanks, I'll definitely check that out.
  3. #12
    May 2005
    N. Seattle.
    5,240
    Too bad the diff is gone. GOLD around here. There must be a LOT of MK II's in Canada.
    There are a LOT in Washington State.Running cars!
    I don't do facepuke,either.
  4. #13
    Junior Member
    Mar 2019
    Calgary, AB
    13
    Quote Originally Posted by ddd228 View Post
    Are diffs that hard to find? I wonder if that's also the case with MkIII Celicas ( think they're compatible?).
    Also curious if there's a way to identify LSD diffs.
  6. #14
    CelicaSupra.com Member Funkycheeze's Avatar
    Feb 2004
    Calgary, Alberta, Canada
    2,456
    All Canadian mk2s are LSD. There should be a sticker on the back diff cover that says 'use only LSD oil'.
    RA6X celica GTS uses the same diff but only the last couple model years.
    '84 P-type, 5spd, Super red, black/grey leather - 2JZGTE swap, Precision 6262 on cast manifold, ECUmaster black with 875cc/min injectors, 465 WHP at 17 psi, built R154 with OS Giken twin plate, one piece driveshaft with 1310 joints, Truetrac with 3.73 R&P, 450 lb/in front coilovers, 300lb/in rear springs, Image BBM wheels 17x8 and 18x10, 4 corner BBK, AGX shocks, Whiteline bars, poly bushings, T3 GTX2 front control and steering arms etc. etc.
  7. #15
    Junior Member
    Jun 2019
    Calgary, Alberta
    14
    I'm glad you brought that up because I didn't notice that on mine. I've just been putting conventional diff oil in it and have been none the wiser. The diff is screwed anyway (it's been howling like crazy since I bought it) so I'm wondering if that's how it came to be bad in the first place.
  8. #16
    May 2005
    N. Seattle.
    5,240
    IF you have an LSD and don't add the friction modifier,you will KNOW IT!
    It will sound like and feel like an earthquake,going around a corner!
    I used Ford stuff.
    BTW: Redline 75W-85 is the frikken' BEST lube for our trannies and diffs. It has the friction modifier already.
    I'm on my 3rd pumpkin,the first 2 were screamers.4.10 LSD's.
    Be prepared to pay 2-4 hundred dollars,U.S. for a used one.
  9. #17
    CelicaSupra.com Member Deanfun's Avatar
    May 2003
    Fort McMurray, Alberta, Canada
    3,246
    I am not a member of this group. Until now.
    Dean L.
    1985 Toyota Supra - Hidden Content
    2000 Lexus LS400
    2007 Lexus LX470
