82 Fuel Sock
Thread: 82 Fuel Sock
    82 Fuel Sock
    Had some driveability issues and discovereebmy fuel sock on the pick up tube is completely deteriorated causing my pump to choke on all the debris in my tank.
    I have the inline pump with the pick up and return tube being what goes in the tank. Any one have ideas on alternatives to the fuel sock? I feel like I wont find one and will have to rig something up, just curious as to what if anything has been tried before.
    8,088
    Shows as still available from Toyota for about $20 if you know where to shop.
    CelicaSupra.com Member supkar's Avatar
    Mar 2005
    Santa Cruz, Ca. 95061
    4,105
    I found one at Vancouver Toyota a couple of years ago.
    You should pull the tank and clean it.
    83-Red P-type , 6M,. LJM strut-bar, RC intake,Thorley header,Tenzo 17" wheels, cross-drilled rotors, Eibach springs, KYB shocks, 85 hatch and int., 82 header panel=Frankenkar
    87 4 Runner, White, 22RE, 302K on original motor, still strong
    "This car is so loud , I heard you before I saw you!" said the nice policeman. Hidden Content
    CelicaSupra.com Member drjim's Avatar
    Aug 2013
    NoCo / Fort Collins, CO
    3,991
    Rock Auto still has them.
    1985 5-speed "Ms. Swan"
    OH, What A Feeling!
    Aug 2019
    Auburn AL
    81
    First if you have that much trash in the tank would be a good idea to pull the tank and clean it out. The tank can be sealed after it is cleaned, there are products we used on motorcycle tanks. I would run a filter external to the tank so it can be changed easier also. If you are set on keeping every thing stock then go back to the in tank sock. If money is no object then Holley has a Hydramat that helps with fuel slosh.
    CelicaSupra.com Member supraz's Avatar
    Vancouver, BC Canada
    885
    The parts are still available.
    In-Tank Fuel sock, (77023-30010, Filter Sub-assembly, Fuel Suction Tube) $20.04
    Matching gasket (77169-14010,Gasket, Fuel Suction Tube Set) $4.56
    In-Tank Fuel sock
    Gasket 77169-14010 in upper portion of picture
    I agree that you probably will want to clean and coat the inside of the gas tank. The size of the filter is only about 2" x 3" so if there is lots of debris in the tank, it will plug quickly.
    Dale
    Black 1983 P Type 5 Spd, Cloth Interior, BBK,HRE 17" Wheels, HKS Exhaust
    White 1984 P Type Auto, Leather Interior, Sunroof, Digital Dash
    May 2019
    156
    they even have them on ebay
    CelicaSupra.com Member Styles's Avatar
    Feb 2011
    Auckland New Zealand
    116
    Just going to add my 0.02 here, and agree with others. Speaking from experience, pull that tank and give it a clean. I also re-coated it with the POR15 kit, that is a bitch of a job though.
    Junior Member Ubara861's Avatar
    Aug 2018
    SoCal
    13
    Thanks for all the info. I was able to find everything at https://www.toyotapartsdeal.com/ Some stuff is a bit vague on the site but having the parts number helped a lot.
    CelicaSupra.com Member 82 Lover's Avatar
    honolulu
    797
    lol i tried buying that tonight and it looks like you have bought the last one....
    Follow me on Instagram! Hidden Content
    its 4:20
