82 Diff F303 = 3.72 engine code but no diff markings?
    May 2019
    156
    So I am pulling the rest of the stuff off a 82 Supra im scrapping, I confirmed on the firewall its got the code F303 with a 3.72 limited slip but I cant find any codes directly on the diff itself, I was going nuts trying to find something to no avail...
    2,456
    With the diff out of the car so both side shafts rotate, spin both side shafts at the same time 10 times and count the number of times the input shaft spins;
    37 and a quarter or so times, means 3.73 (actually 3.727)
    39 means 3.90
    41 means 4.10
    43 means 4.30
    It should have a sticker on the aluminum cover if it is LSD, although it can be missing on an older car.
    '84 P-type, 5spd, Super red, black/grey leather - 2JZGTE swap, Precision 6262 on cast manifold, ECUmaster black with 875cc/min injectors, 465 WHP at 17 psi, built R154 with OS Giken twin plate, one piece driveshaft with 1310 joints, Truetrac with 3.73 R&P, 450 lb/in front coilovers, 300lb/in rear springs, Image BBM wheels 17x8 and 18x10, 4 corner BBK, AGX shocks, Whiteline bars, poly bushings, T3 GTX2 front control and steering arms etc. etc.
    May 2019
    156
    Quote Originally Posted by Funkycheeze View Post
    39 means 3.90
    41 means 4.10
    43 means 4.30
    Dam bro that's awesome your like the mighty supra book of wisdom lol... I really appreciate that im going to give it a go, the diff appears like it was never removed so hopefully its the correct one
    7,366
    F303 = 3.727...if the last digit is a 3 = LSD
    https://www.celica-gts.com/resources...ial_codes.html
    7,366
    IF your really lucky find a RA65 LSD 1985 GTS only... 3.90 ratio F313?? IIRC
    May 2019
    156
    Quote Originally Posted by AJ View Post
    How rare are those? Did they come in anything else?
    7,366
    LSD fairly rare, non-LSD in most RA Celica...
    May 2019
    156
    I now will need to start looking
    Jan 2018
    Indiana
    1
    Hello,
    Are you interested in selling the 3.72 posi rearend? Thank, Paul G (teqsupra)
