Adjustible rear lowering springs on Yahoo japan
Results 1 to 10 of 15
    May 2019
    156
    Says these are new style, Anyone seen these stateside?
    https://page.auctions.yahoo.co.jp/jp/auction/c754243685
    CelicaSupra.com Member Zerodrag's Avatar
    SoCA
    475
    The Megan coilover kit for the Cressida uses a similar rear setup.
    May 2019
    156
    Quote Originally Posted by Zerodrag View Post
    this one??
    https://meganracing.com/suspension/t...-cdk-mx73-4303
    SoCA
    475
    I believe so. BC also makes a set of similar coilovers.
    CelicaSupra.com Member MrBubbles00482's Avatar
    Dec 2010
    Txk, AR
    789
    Yuhp, Megan and BC racing make coilovers that are the same setup with a seperate spring and shock. Gecko also makes them this way.
    T3, Stance, and Ceika(maybe) are a coil over shock setup in the rear.
    1985 P-type "Elvira" Blue inside out.
    2jzge/w58 swapped
    MECP advanced autotech
    May 2019
    156
    what set up do you guys think might be better for street and improved handling and maintain ride quality? Want to lower car with minimal gap not into rolling fenders ect… but want the least rough ride as possible too, I guess everything has a trade off but I guess if you guys have any of these set up you would know best with trying to achieve something close to what I want,
    Megan, BC racing,Gecko (coilovers with a separate spring and shock.)
    T3, Stance, Ceika (coil over shock setup in the rear)
    KYB struts/shocks with Dobson King springs
    Mar 2015
    San Diego
    210
    I am considering the same conversion as you. The one point of concern for coil over shock in the rear is that the top tower mount is already a bit weak on the body so adding stress to it without reinforcement would certainly cause metal fatigue in short order.
    10,162
    Any serious changes in rear ride height will require a serious camber mod to bring the toe and camber back in line. Our stupid IRS changes geometry dramatically with small ride height changes.
    Keep in mind all rear springs for our car are 1 way adjustable already. The ol angle grinder can adjust them to whatever height you want
    10,162
    double post
    May 2019
    156
    Quote Originally Posted by SupraFiend View Post
    what is the lowest drop you suggest without screwing up the toe and camber?
