7MGTE and air conditioning
    Dec 2018
    Olympia, WA
    9
    Just wanted to run a quick poll to see who has kept their AC after swapping in a GTE motor, whether it's a 7M or 1/2JZ. I'm most of the way done with a 7M swap, currently with the AC components still installed and the fabricator building pipes for the front mount intercooler is going to be expensive and complex due to the number of bends and such that will be required. Are most people deleting their AC when doing a GTE swap? The front mount being used is a Driftmotion unit with the inlet and outlet on the same side.
    1983 P-Type
    2015 AH-64E
    2,458
    I removed mine, but up here in Canada, we don't have many really hot days in the summer where you would want AC - most of the summer it is 65 to 75F. Note with my 2JZ swap it has the factory front facing intake and I have an intercooler with an inlet on one side and outlet on the other so the piping is massively simplified compared to a 7M swap.
    '84 P-type, 5spd, Super red, black/grey leather - 2JZGTE swap, Precision 6262 on cast manifold, ECUmaster black with 875cc/min injectors, 465 WHP at 17 psi, built R154 with OS Giken twin plate, one piece driveshaft with 1310 joints, Truetrac with 3.73 R&P, 450 lb/in front coilovers, 300lb/in rear springs, Image BBM wheels 17x8 and 18x10, 4 corner BBK, AGX shocks, Whiteline bars, poly bushings, T3 GTX2 front control and steering arms etc. etc.
    I have done the 2jz ge swap and deleted the AC. Mine didn’t have AC from before, but the new engine did have the AC pump etc. Living in Norway there is no big need for AC, specially not with a sun roof 🙂
    8,091
    I've had ac on both 7m and 2jz swaps now. Kind of a requirement in California here.
