yota fanatic's s13 rear subframe swap
Results 1 to 10 of 11
    CelicaSupra.com Member yota_fanatic's Avatar
    Feb 2009
    Huntsville, AL
    550
    I decided to ditch the old trailling arm setup and go with a more modern suspension setup.
    After some research I chose the s13 240sx.
    Tons of aftermarket support, plenty of diff options, and easily converted to 5 lug.
    using my parts car for mock up
    front mounts extended
    I still have to finish boxing and welding the rear mount pads and figure out what coilovers to use.
    1984 White MKII P-Type, 2jzge
    1985 Black P-type 1jzgte vvti
    1996 sc300 2jzget
    Need precision welding?
    CelicaSupra.com Member MrBubbles00482's Avatar
    Dec 2010
    Txk, AR
    790
    Nice, a couple other people have done this as well. I have a full rear s13 subframe sitting on a shelf waiting to get this done too.
    So you extended the fronts of the s13 subframe to fit to the supras stock studs? Are the rear studs you added in cut from an s13 or did you make those?
    1985 P-type "Elvira" Blue inside out.
    2jzge/w58 swapped
    MECP advanced autotech
    Whistles racerxj220's Avatar
    Anywhere I want.
    1,043
    Looking great, William!
    Feb 2009
    Huntsville, AL
    550
    Quote Originally Posted by MrBubbles00482 View Post
    Yeah I know but non of them shown any good pictures on how they have done it. So I decided to make a thread on how I am doing it.
    Yes extend the front. Make new mounting locations for the rear. The rear studs are the rear mkii studs.
    1996 sc300 2jzget
    Dec 2010
    Txk, AR
    790
    Quote Originally Posted by yota_fanatic View Post
    Exactly!, no one has had in depth documentation on it with pics like this I don't believe.
    Nice, and all the studs are the proper size?
    2jzge/w58 swapped
    CelicaSupra.com Member BillyM's Avatar
    Charlotte, NC
    13,016
    Very nice swap - looking good!
    --billyM
    White 85P - Blue/Silver 85P
    Feb 2009
    Huntsville, AL
    550
    This supra studs are a little bit smaller than the s13
    1996 sc300 2jzget
    Jun 2006
    San Antonio, TX
    19
    Nice!
    Been telling the MX71 guys to do this for decades.
    They never do, instead they just complain about broken stub shafts...
    10,188
    Ha ha, I've been telling people to do this for decades here too lol. So much simpler then modifing the stock subframe to fit an 8 inch diff (though perhaps not simpler then the rare 85/86 Soarer one).
    I almost went for this IRS, but the mk3 Supra one looked a little simpler to fit. I do like the option of keeping the 4 bolt setup though, and perhaps the track width is a touch less.
    Whats your plan for mounting shocks? is it going to line up close enough for the stock mounting point or are you going to have to graft in different towers?
    Feb 2009
    Huntsville, AL
    550
    Quote Originally Posted by SupraFiend View Post
    I was going to weld the s13 strut towers in but I think I can get away with just using a custom coilover. I will have to use the half moon upper control arms for coilover to clear. The mkii upper shock mount is a little farther back than the s13.
    1996 sc300 2jzget
