Drivers side wiper adapters
Results 1 to 10 of 19
    CelicaSupra.com Member aerojock's Avatar
    Dec 2007
    tx
    795
    I know that we all would like to be able to replace the drivers side wiper with just a quick cartridge change. The stock wiper won't do that so unless you change the arms with Celica arms what options do you have. I want to keep the original style but be able to replace them with cartridges so I modified my drivers arm to take an adapter for wiper cartridges. Here is what I did. Took about 20 minutes.
    I tried it with a spare arm I had. I had these adapters already but I believe the are Bosch adapters.
    I found these on Amazon.
    https://www.amazon.com/Windshield-Wi...wiper+adapters
    Here is where I mounted the adapter.
    You will need to remove these two rivets. I used a grinder and a punch but you can try to drill them out.
    Rivet A.
    Rivet B.
    This pin needs to come out. I used a grinder with a thin blade but a saw might work. This is also the head of rivet A
    With the wiper blade and blade arm removed you can see the other side to rivet B. You will need to remove rivet B now.
    With the rivet B now removed you can take off one side of the channel off.
    This leaves the other channel side. This will need to be ground off too.
    It has now been groung off to be even with the bottom of the channel.
    The adapter.
    As you can see the adapter holes match the spacing of the holes on you wiper arm. They will need to be drilled out so a 1/8 inch pop rivet will fit.
    You can rivet or bolt on the adapter either on top or underneath the arm. If you choose to do it on top I suggest grinding of the bottom of the adapter side to be flush. This will allow better mating to the wiper arm. ( It is what I did)
    Finished product.
    The second adapter mounts directly to the passenger wiper arm so no need to modify it.
    CelicaSupra.com Member Stratocat's Avatar
    Jun 2014
    PDX
    235
    Nice writeup.
    83 P Type
    83 P Type
    85 P Type
    CelicaSupra.com Member drjim's Avatar
    Aug 2013
    NoCo / Fort Collins, CO
    3,947
    Pretty slick!
    Is the adapter piece metal? It looks like it, but just asking to be sure.
    - Jim
    1985 5-speed "Ms. Swan"
    OH, What A Feeling!
    Dec 2007
    tx
    795
    Quote Originally Posted by drjim View Post
    Pretty slick!
    - Jim
    It is metal.
    CelicaSupra.com Member 4SFED's Avatar
    E. Chugabrew, Wisconsin
    5,512
    I found these on ebay. $7.59/pr. US seller.
    For those that don't care whether it's a US seller, they're only $5.99 a pair from Hong Kong
    current lineup and year acquired:
    '85 white Mark2 7mgte 5sp 1988
    '85 white Mark2 7mgte Auto 2009
    '84 maroon Mark2 6mge 5sp 2013
    '86 red Mark2 7mgte 5sp 2016
    '85 black Mark2 6m Frankenmotor 5sp 2017
    CelicaSupra.com Member gamble's Avatar
    Austin, TX
    3,261
    Nice work man.
    Hidden Content 86 parts car maybe some day race car? 3x cars, 36x brake caliper pistons.
    "You need to update your signature Gamble" - Dave
    Dec 2007
    tx
    795
    The adapter bolts straight on to the rear wiper also.
    CelicaSupra.com Member racefanfoster's Avatar
    May 2008
    CRIME FREE Olive Branch,MS... Everybody carrys a GUN!
    959
    nice work there
    2,432
    What about the passenger side? I haven't looked at doing this, but I am now interested..
    '84 P-type, 5spd, torrid red, black/grey leather
    Built 7MGTE (JE's, ARP studs, MHG), BOSS STG4 60mm, AEM standalone, R154, 2 1/2" IC and 3" turbo back - the works
    Coilovers, ROH wheels, 4 corner BBK, Konis, ADDCO bars, PST bushings etc. etc.
    Dec 2007
    tx
    795
    The adapter bolts directly on to the passenger side.
