Brake conversion - Page 13
Page 13 of 52 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 512
  1. #121
    Supra since '86 rsdeo's Avatar
    Apr 2003
    Burlington, Ontario. Canada
    5,472
    Quote Originally Posted by williamb82
    i want it to stay the same cause i plan to keep a nice fat lip on all the wheels. honestly for brakes, ill prolly use this same brake upgrade up front you just posted as final. itll be easir as i wont have to redril the rotor to a 4 bolt pattern.
    william
    You will loose some lip. The Z32 caliper is so wide that it will rub the spokes if the right wheels are not chosen. My rims will clear the Z32 calipers no problem and being a 8.5" wide rim I still get 2.5" of lip.
    That said you a better off getting the later Z31 front hubs because there is machining required and everything just bolts up. Also with a 17x8"wheel you should need an offset of +20 to +25 Lot's of wheels out there that size and offset.
  3. #122
    Spring Hill, Fl.
    15,002
    where? i cant find any. and id like up to 17x10 for the rear. i figure 17x10 +13 will fit perfect in the rear, but if i do the upgrade baachy did prolly +20 will work as the rotor is a lil thicker on the face iirc.
    william
    Black 84 7mgte/R154, MS2, truetrac, bbk, etc...soon to have 2jzgte and t56
    Blue 85 Beater. TRD Header, HKS Exhaust, custom 3in intake pipe, cone filter
    Black 86 Triple Weber 6m Eventually
    Rusty 85 Frankenstein 6M/w58 with DIYPNP
  4. #123
    Spring Hill, Fl.
    15,002
    Quote Originally Posted by rsdeo
    Stock rear MK2 disc is far too small at 266mm in diameter and 18mm thick for the Z32 caliper. The mounting points for the caliper on the rear control arm of the MK2 is ~160mm apart, so a mounting braket would also be required.
    stock disc is 266mm diameter and 18mm thick, these discs are 300mm and 22mmthick and are obviously too large in diameter. and the 4mm thinner rotor shouldnt be an issue. thats a max of 2mm thick spacer needed for each pad, and i dont think it would be an issue at all as long as you have the 2psi risidual valves, these calipers should work for the rear as long as we can find a way to mount them. guess i need to buy a pair and see what needs done. im sure i can get it done.
    william
  6. #124
    William,
    PM PeeWee on these forums, as he is doing a brake upgrade that utilises either the std or GTR version of the R32/Z32 front brakes as well as teh rear discs and calipers.
    Still in 4 stud as well.
    Redrilling a rotor is very easy, and if careful can be done at home.
    I saw the last payment, thanks very much. I'll let you know as soon as they are on their way
    Cheers
    Michael B
    PS - I'll be making sure that they are well packed and protected !!!!
  7. #125
    Apr 2003
    5,472
    Quote Originally Posted by bbaacchhyy
    William,
    Cheers
    Michael B
    Another 5 bolt conversion... cool.
  8. #126
    I can post pics of my conversion if you guys are interested. It's the nissan r33 setup, with the 300mm rotors redrilled to 4-stud.
  9. #127
    CelicaSupra.com Member joefoe's Avatar
    Sep 2003
    Courtenay BC (Island Life)
    862
    Quote Originally Posted by joorsh
    please do!
    Just an 82 supra Hidden Content
  10. #128
    Quote Originally Posted by joefoe
    please do!
    Another variant - Great to see some different setups that are now available to the Supra community
    How many variants does that make now ? Should provide a list of the key characteristics and the contact for other forum members
    Cheers
    Michael B
  11. #129
    CelicaSupra.com Member Chrisfrom1986's Avatar
    Feb 2005
    Fresno, Ca
    6,499
    how much was the final cost? i imagine its going to be a real pain in the ass for us in the US costwise to get these parts.
  12. #130
    Spring Hill, Fl.
    15,002
    i think ive got a setup that will fit inside 15in wheels with 4 piston calipers. should know more this weekend or next. got some more parts to grab.
    william
    william
