helpfull tips and tricks! - Page 4
Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. #31
    CelicaSupra.com Member Donn29's Avatar
    May 2004
    Windsor, Ontario
    6,312
    Old Head bolts are perfect!
    Supra Rehabilitator.
    Black 86 with 7M-GTE/W58/3.58/TrueTrac, 300whp, [email protected] Now on MS3X.
    Hidden Content Hidden Content Hidden Content Hidden Content Hidden Content Hidden Content
    Hidden Content Originally Posted by Tire Shredder Hidden Content
    "surprise! this one runs 11s biatch"
  3. #32
    Spring Hill, Fl.
    15,001
    Edited post 1. bread works better and faster than the wet paper towels. also added some stuff to post 8. How to replace the starter in 10-15min, and how to keep bolts/nuts from being lost out of your socket when dealing with difficult bolt/nut locations.
    william
    Black 84 7mgte/R154, MS2, truetrac, bbk, etc...soon to have 2jzgte and t56
    Blue 85 Beater. TRD Header, HKS Exhaust, custom 3in intake pipe, cone filter
    Black 86 Triple Weber 6m Eventually
    Rusty 85 Frankenstein 6M/w58 with DIYPNP
  4. #33
    Member
    Nov 2017
    los angeles, ca.
    62
    Quote Originally Posted by MKIIproject View Post
    How do you know when the intake and exhaust valves are closed on #1 cylinder, would I have to pull the valve cover?
    Take off distributor cap, bring rotor to pointing at #1. This how I adjust valves... follow rotor and adjust each cylinder...
  6. #34
    Spring Hill, Fl.
    15,001
    Easiest way is to take the upper timing cover off and turn the crank until both cam timing marks line up with the rear cover.
    william
