Phil and Greg's AC Party - Page 7
Page 7 of 7 FirstFirst ... 567
Results 61 to 67 of 67
  1. #61
    CelicaSupra.com Member jdk_ii's Avatar
    Bawsten
    1,948
    Quote Originally Posted by Daves7MGTE View Post
    Holly Fargen POO BATMAN!!!! I have cold ac................ With twin E fans on the rad and blocking off the area forcing the air to pass threw the condenser to get to the rad worked wonders. So i have no spal fan on the condenser itself. I have the E fans on the rad also wired up to the ac system so if the ac is on so are the fans. I need to get a thermometer to reed vent temps.
    TITE, YO!
    It would be good to know your vent temps vs ambient since you are in a drier climate.
    That in combo with your E-fans and a "tiny" intercooler.
    Jim
    MK2 Geek Squad Member
    Hidden Content
  3. #62
    May 2005
    N. Seattle.
    5,237
    Pusher fan?
    I didn't see what you used. I mounted a 12" Derale in front of my condenser.Took a lot of time-the stock one is very small! A 10" would have been easier.I hope I never have to remove the evaporater-looks like a PITA.Wonder how much crap is in there...
  4. #63
    May 2005
    N. Seattle.
    5,237
    Quote Originally Posted by jdk_ii View Post
    There's truth to this. R134a does require more heat exchange than R12.
    Though contrary to some web info, R134a is actually more efficient.
    Some Mk2 owners have reached results with 45F at the vents. Which is average with any new car.
    Some have reported 50F, which basically takes the heat edge off.
    The MK2 condenser is rather small, and my research indicated it was borderline for R134a.
    Those I consulted said if I wanted frosty nipples (well, not in that exact terminology), they said use a more efficient condenser.
    So I did. And some have suggested I rename the kit.
    Here's a link to a FAQ that may provide you some more information.
    http://forums.celicasupra.com/showthread.php?t=32211
    Greg is correct. The kit used Spal fans. 10" or 11". Don't recall.
    Yes, most any aftermarket fan will need to be wired seperately from any factory feeds.
    You can use the existing fan feed as the relay trigger.
    I used a a DeRail 12" but it's a tight fit.DOABLE! 10" is easier to install. It will take some custom fitting. WORTH it. The air flow is HUGE! I use it to cool the engine. 20 AMP fuse. The stock fan is a weenie. Take it all out and you will see what you have to do,there. I posted it WAY back. My system is on it's way out so I needed max air flow-best I can do for now.
  6. #64
    CelicaSupra.com Member supraz's Avatar
    Jun 2003
    Vancouver, BC Canada
    881
    Quote Originally Posted by Greg G View Post
    Here Joe is making easy work of rebuilding my EPR...
    Okay, I know this is an extremely old thread, but I was able to snag one of the original JDK A/C Upgrade kits and am looking for the instructions on rebuilding the EPR Valve.
    I have the instructions for the installation, but the instructions indicate that there is a second manual for rebuilding the EPR Valve.
    The Evaporator Pressure Regulator in this application is only being used as a coupler. The Evaporator Temperature is controlled by a temperature sensor that cycles the compressor on and off.
    I would like to find out how the EPR valve is disabled.
    Any help from owners of the JK AC Kit would be greatly appreciated.
    Dale
    Black 1983 P Type 5 Spd, Cloth Interior, BBK,HRE 17" Wheels, HKS Exhaust
    White 1984 P Type Auto, Leather Interior, Sunroof, Digital Dash
  7. #65
    CelicaSupra.com Member AJ's Avatar
    SF Bay Area
    7,364
    Dale, found this on the forums but not a lot of detail...
    https://www.celicasupra.com/forums/s...egulator-(EPR)
    And Google search
    https://books.google.com/books?id=b9...0valve&f=false
    Regards,
    Arch
    '86 Supra MA67
    Brullen 2.5" Exhaust, HKS Fly w/7MGE clutch,ST Springs, RC Intake & TB, 2.8GT & XX emblems, Factory Add on Rear Shoulder belts, Pioneer DEH-P2000 AM/FM/CD w/CDS-P5000 CD Player, Compomotive CXNs 8x16
  8. #66
    SF Bay Area
    7,364
    Dale, this Lexus vidoe bypassed the EPR !!
    https://www.youtube.com/watch?v=LIAV8LY52ZE
    Regards,
    Arch
    '86 Supra MA67
  9. #67
    Santa Clara & Stockton, CA
    8,074
    Just a tip, but the epr is still available from Toyota. I replaced mine last year. Blew my mind that it was still available...
