RPM-MPH chart for W58 & stock wheels/tires - Page 11
Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 101 to 110 of 121
  1. #101
    CelicaSupra.com Member 83CelWA's Avatar
    Nov 2004
    Graham, WA
    5,448
    Quote Originally Posted by kmfdmk View Post
    From that chart it WOULD IT ? be safe to deduce that all mk's either came with a 41 or 43 tooth RING, and either an 11, 12, or 13 tooth PINION? Now.... question... is it possible to take a 4.30 RING and merge it with any old 12 tooth Pinion?? Other than getting the gears meshed properly would this be a problem? Either way that'd get me either a 3.42 or a 3.58, NOT bad ... plus I'd see another 20% on my mileage!! (Though 25mpg @ 75mph & 400hp aint bad, I'd love to see 30mpg)
    IIRC, in '85 when the Celica GT-S finally got a 7.5" diff, it used the 3.58.
    -Chris
    1983 Celipra GTS:
  3. #102
    CelicaSupra.com Member Austin E's Avatar
    Jan 2006
    Rancho Santa Margarita, Ca
    2,136
    Quote Originally Posted by zuprax85 View Post
    mine is an 84 original , was an automatic (body), i did the 5 speed swap (85 5mge + w58).
    You have a 4.10.
    It will say f293 on your data plate.
    Austin Easley
    1984 Light blue Mkii
  4. #103
    CelicaSupra.com Member Chrisfrom1986's Avatar
    Feb 2005
    Fresno, Ca
    6,499
    Yes, if that chart is accurate then that is true.
    If so then it would seem that we only need the pinion gears to create our own 3.58 and 3.42 gears.
    The problem is still sourcing the 12 tooth pinion gear.
  6. #104
    CelicaSupra.com Member zuprax85's Avatar
    Aug 2008
    baltimore
    3,224
    we have to contact Mark........
    Edgar M.
    85 Two tones P-type 5 speed R.I.P Hidden Content
    84 White P-type 2JZ-GE 5 speed Hidden Content
    Hidden Content
  7. #105
    Aug 2008
    baltimore
    3,224
    it will be awesome if i can get 25 + mpg at least.
    Edgar M.
    Hidden Content
  8. #106
    POTATO Tanya's Avatar
    Jul 2003
    Fort Myers, FL
    17,179
    Quote Originally Posted by 83CelWA View Post
    WAT.
    I know the '85 Celica convertible I had was a 7.5" 3.90 non LSD. Totally NOT a 3.58.
    Hidden Content
    Hidden Content
    Hidden Content
    -shirts, stickers, posters & more!-
    Hidden Content
    -more shirt styles, magnets, wallets, mugs and more!-
    1985 P-type 5 speed
    6MGE
    10 years strong 4-20-08
    1984 L-type Auto - Bone stock & broken Hidden Content
    acquired 6/17
  9. #107
    CelicaSupra.com Member CarFreek's Avatar
    Auburn, WA.
    6,070
    First off, 3.42 and 3.58 matching sets are available-Application was 2wd Toyota truck from 88-95ish, and front pumpkin of some 4x4 trucks from same time range. Ive got a 3.58 in my car from one, and last I heard, they were available new from Mark. Second, the pinions have different tooth pitch and ODs, so they wont mix and match on the ring gear. BTDT. I got my 3.58 from PnP for $30. If the possible Donor Vehicle has a 4speed, its one of these ratios....The Data plate section of the FAQ shows the codes to look for.
    86 SDR-"Shuttlecraft" 16" Drag dr-27 wheels, T3Coilover front, Camber Mod/Cut Springs rear, Poly Bushings all around, Whiteline sway bars, 13" bbk front, and 12" bbk rear, 1gz-fe V12 swap. 84 blue two tone 1uz swap. Whitelines and dobinsons and advanced iron oxide mass reduction.
  10. #108
    is awesome kmfdmk's Avatar
    Oct 2004
    Richland, WA
    2,736
    Quote Originally Posted by CarFreek View Post
    That's exactly what I was anticipating, different gear/tooth angles. Not a big deal, thanks for the refresher on what vehicles they come in.
  11. #109
    Member xxxbenderxxx's Avatar
    Oct 2008
    Shepherdsville Kentucky
    36
    Quote Originally Posted by Tanya View Post
    whew, I've pinned speedo @ 130 @ about 6000rpms w/ 4.30 gears which appears to be accurate comparing to the chart... I would like to see someone w/ a stock n/a mk2 "officially" top their car out @ redline and see what mph that would be...just can't figure out a way to get a speed check unless you have a cop friend who'll clock you, heh
    or maybe an aftermarket speedo that does over 130? I dunno
    I think Norbie has said he's done 160mph but that's definitly NOT stock...
    all mag articles I read has the mk2 topped at 130mph, so is the car not supposed to pick up even a little more speed if it still has a few more rpms to go?
    a tom tom GPS would tell you what speed you are at.
  12. #110
    CelicaSupra.com Member Dakar2008's Avatar
    Jan 2006
    chicago, illinois
    657
    chart doesn't seem right. im at 80 mph in 5th @ 3000rpm W58 and 3.73 lsd gps confirmed 205/60/15
    5M-GTE 86 5sp cressida certified used toyota edition
    Hidden Content
    Hidden Content
